Transmisson warning light - BMW Forum - BimmerWerkz.com
Old 02-02-2012, 08:18 PM   #1 (permalink)
mincohome is on a distinguished road
I have a 1996 328I automatic transmission older drives good but sometimes when I turn it off the transmission wraning light will come on and then the transmission is in safe mode. I can turn the car off and wait a few seconds turn it back on and it will go off and drive fine. what do you think it is any ideas.
mincohome is offline   Reply With Quote
Old 02-03-2012, 11:56 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
As a calculated guess, I would change the tranny oil and maybe change or replace tranny filter. HTH
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 02-06-2012, 07:54 AM   #3 (permalink)
life time transmission
my transmission warning light comes on I want to change the fluid and possibly the filter to see if it corrects the problem light comes on I turn the car off wait ten seconds turn it back on it resets and operated fine. what about eh life time fluid I do have 200,000 miles on this vehicle and think it would not hurt to change the fluid please advise
Old 02-06-2012, 09:07 AM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Well you have an OBD-II car so you could take it to an auto parts store or mechanic and have the system scanned for trouble codes. That would give you an idea of if the car believes theirs a fault in the system.
I'm an advocate of changing the trannsmission fluid. Everyone gets confused by BMW's statement of "lifetime fluid". However that statement is meant to be the lifetime of the trannsmission. So if the tranny lasts 100,00 kim then that was its lifetime. However, ALL synthetic fluids break down over time. And because of this they should be changed. Some people report better shifts after having done it so their can be a benifit.
PelicanParts.com has a transmission filter and gasket kit available. All you need is the Trannsmission fluid. For that most people recommend Redline fluid.
Old 02-06-2012, 09:26 AM   #5 (permalink)
Yes I agree with you on the fluid and yes i think I will take it to get the error code read to determine if it is something more serious. I am just concened about the type of fluid to replace it with. It does not seam serious at all just eh sensors or computer telling me to do some type of service
Thank you
Old 11-15-2012, 12:01 PM   #6 (permalink)
Jeff328i's Avatar
Car: 1996 328i Convert
Jeff328i is on a distinguished road
I too am having the tranny light come on and the trans go in to limp mode. Decidedly came to to BimmerWerkz to aquire wisdom and knowledge. So does anyone know how this saga ended?
Jeff328i is offline   Reply With Quote
Old 11-23-2012, 08:25 PM   #7 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
The transmission goes into limp mode to protect itself when a fault is detected. You should go hav the OBD system scanned for trouble codes. The codes will give you a code idea of what is wrong, and we can help you better from their.
Click HERE to see my E36 Blog
Old 11-26-2012, 01:57 PM   #8 (permalink)
Jeff328i's Avatar
I did check the code with my reader and there were more than a few; Fuel Trim, Cam Position Sensor, MAF, TPS. So I thought I'd put the old MAF back in for a reference point. Now I still get the Fuel Trim, Cam Position Sensor, but the tranny doesn't fail, nor the MAF, TPS. Seems odd, No? The OBD system seems to be so intertwined with all of the feedback sources one can hardly ascertain the root cause. Quite the quandary!
Old 12-02-2012, 02:34 AM   #9 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
If your getting CPS and TPS codes i would clean the sensor with contact cleaner and see if that clears the code. If not, replace the sensor.
With the car running, unplug the MAF. If the idle gets better, then the MAF is faulty.
Old 12-10-2012, 12:57 AM   #10 (permalink)
rajendersingh90 is on a distinguished road
maybe i am not sure but that problem could be related with the battery of your car? there is no harm in checking up the battery of yours here...
rajendersingh90 is offline   Reply With Quote
ABS Warning light beemer 46 3-Series (E36) 2 05-19-2008 09:10 AM
warning light? turbodiesel 3-Series (E46, E90) 11 01-28-2005 11:29 PM
Bmw 730i Transmisson Problem redmondp 1,6,7,8 - Series and Mini Cooper 5 01-25-2005 08:28 AM
Dinan transmisson chip BUSTaMOVE 3-Series (E36) 16 04-01-2004 11:14 PM
Tail Light Warning Light Black530MT 5-Series (E12,E28, E34, E39, E60) 1 02-28-2004 05:20 PM
