Transmission Problem - BMW Forum - BimmerWerkz.com
Old 07-19-2004, 12:04 AM   #1 (permalink)
logantv88iX92is is an unknown quantity at this point
When I shift from first to second, there is no problem. But when I downshift from third to second (rarely, only at slow speeds, not to pass), the transmission kicks it out of gear when I let up the clutch. It does it the most when I go around a corner with the clutch in and try to go into second for the exit. It feels fine when I shift into second, it's not untio I let out hte clutch that it kicks it back to neutral. I've found that I can get around it by blipping the throttle a little bit too high before I let out the clutch, sort of like how you would do if you were driving clutchless. The clutch feels fine otherwise, and it's never happened in any other gear. I'm probably going to put on an X-brace anyway, but I don't think it's an alignment/mount issue. The way I have to blip the throttle first points towards a synchronizer, but I really don't know transmissions that well. Has this ever happened to anybody else?
1988 325iX Alpine White
1992 325is Dark Metallic Blue (?)
<img src='http://members.roadfly.org/logantv/Racing_Honda.jpg' border='0' alt='user posted image' />
logantv88iX92is is offline   Reply With Quote
Stick Shift Problem, Transmission ilDawg M-Series (M1, M3, M5, M6) 0 09-16-2005 08:10 PM
2001 540I Transmission Problem dukesmg 5-Series (E12,E28, E34, E39, E60) 1 09-12-2005 07:28 PM
Transmission Problem colt1210 5-Series (E12,E28, E34, E39, E60) 0 07-22-2005 07:07 PM
2000 Bmw 323ci Transmission Problem Max24 3-Series (E46, E90) 3 01-07-2005 03:50 PM
e30 transmission problem milpitas325i 3-Series (E21, E30) 4 05-29-2004 01:06 AM
