Transmission Fluid - BMW Forum - BimmerWerkz.com
Old 10-14-2004, 07:56 PM   #1 (permalink)
cyanni is an unknown quantity at this point
I have a small leak up by the radiator junction block. All I want to do is to top off the transmission at the side filler plug. I've read the transmission caution tag and it say's Use dealer part# 83229407858 or 859 Dexron III only. So the questions is.... can I just go to any auto parts store and by off the shelf DexronIII and top off the transmission? If I can do that then what is the best compatible manufacture of Dexron III out there. I really don't want any mixing incompatibilities.
Thanks for the help.
cYanni
cyanni is offline   Reply With Quote
Old 10-14-2004, 08:11 PM   #2 (permalink)
Kevin325i's Avatar
That's your power steering. It's common for the tube underneath to leak.
Kevin (President TBEA)
323i Transmission Fluid Hunter22 3-Series (E36) 4 04-18-2005 12:22 PM
Transmission Fluid - Atf, Dexron Iii, Slf.... Wtf? bitcore 3-Series (E36) 8 11-24-2004 09:58 PM
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 09:12 PM
Automatic Transmission Fluid / Steering Fluid akbarz 3-Series (E46, E90) 1 08-23-2004 02:04 AM
Transmission Fluid Kevin325i 3-Series (E36) 8 05-20-2004 09:48 PM
