transmission? - BMW Forum - BimmerWerkz.com
Old 08-31-2004, 12:41 PM   #1 (permalink)
/Banned
okczy21 is an unknown quantity at this point
when im on the highway and punch it my transmission revvs up and down
okczy21 is offline   Reply With Quote
Old 08-31-2004, 12:41 PM   #2 (permalink)
/Banned
like its stallin or something, what is wrong with it?
Old 08-31-2004, 12:44 PM   #3 (permalink)
nycbmw325is is an unknown quantity at this point
Ugh... AT or manual. can you be more specific in describing the problem? is your engine revving up and down or is is it the tranny? More details = better answers= less irrelevant ones
(incidentally I promise not to bash any response to this post because who the hell knows what is going on from the minimal information provided)
nycbmw325is is offline   Reply With Quote
Old 08-31-2004, 04:00 PM   #4 (permalink)
BMWBeauty416's Avatar
Car: '00 M-B CLK430 Cabriolet
BMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to allBMWBeauty416 is a name known to all
Send a message via AIM to BMWBeauty416 Send a message via MSN to BMWBeauty416 Send a message via Yahoo to BMWBeauty416
does it like sometimes pick up when you push the petal and sometimes when you floor it do nothing? (might have an idea if so)
~*Teg*~
BMWBeauty416 is offline   Reply With Quote
Old 08-31-2004, 05:31 PM   #5 (permalink)
Threadkiller
bitcore's Avatar
Whatever it is, that sounds like a slipping cluch which is the most common diagnosis of this symptom, but it could be lots of things since you didn't give us enough information about what's going on.
If you have a manual transmission: A slipping clutch is probably what you have. You press the gas, and the engine revvs high, but you arn't accelerating like you normally would. This is a bad thing and the clutch needs to be replaced otherwise it will just get worse untill you reach the point where the car WONT accelerate anymore. Clutches wear out, just like brake pads, rotors, and tires do.
Provide us with more info: Is your car automatic or manual? Does this occur when you are keeping a steady speed or just when you accelerate and put extra force on the drivetrain? Does this happen in any specific gear or does it happen to all of them?
Old 08-31-2004, 07:35 PM   #6 (permalink)
/Banned
its an auto, if i drive normal everything is cool, lets say i gas it real hard, it will rev up to 4000 then drop to like 2500 repeatedly until i let off the gas, but if i start driving normal again its cool, this doesnt happen everytime i punch it probably like 50 percent of the time
Old 08-31-2004, 07:37 PM   #7 (permalink)
Threadkiller
bitcore's Avatar
I'm guessing either damaged control unit, torn up amd malfunctioning torque converter, or the transmission's poping out of gear or something.
If it's really bad or it gets worse, I'd probably bite the bullet and take it to a dealer and get some codes scanned & checked out, or at least call them and speak to a mechanic about the problem unless someone else here has an opinion.
Old 08-31-2004, 08:13 PM   #8 (permalink)
thekid's Avatar
does the car still accelerate when it drops down to 2500 rpms from 4000?
Old 08-31-2004, 08:27 PM   #9 (permalink)
/Banned
it will accel up to 4k then drop back down 2500 then accel back up then back down until i just let off the gas totally
2000 Bmw 323ci Transmission Problem Max24 3-Series (E46, E90) 3 01-07-2005 03:50 PM
'85 325e 5-speed manual transmission xyzzy 3-Series (E21, E30) 3 09-15-2004 03:23 PM
E38 Sport Transmission Problems oracleman 1,6,7,8 - Series and Mini Cooper 2 02-22-2004 04:51 PM
