Tranny Fluid - BMW Forum - BimmerWerkz.com
Old 02-25-2005, 11:46 AM   #1 (permalink)
OldGuy is an unknown quantity at this point
Thumbs up
I'm thinking about having the Transmission fluid purged and replaced and need to know if I have to stick with a particular brand/type. I read about checking the fluid and the level being critical and checked at an exact temperature range...This is for a 96' 328iS..............
Thanks
~Mark Robert~
OldGuy is offline   Reply With Quote
Old 02-25-2005, 11:57 AM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
i am allmost sure.. that everytranny fluid is the same... they all do the same thing!!
if your a little hesitant.. then just buy the moste exspensive 1...
-SOLD..
R.I.P Fast 6
Old 02-25-2005, 12:02 PM   #3 (permalink)
Silverstreak is an unknown quantity at this point
Mobil 1 ATF is what I use and it's great
<a href='http://www.cardomain.com/memberpage/237652' target='_blank'><img src='http://img170.exs.cx/img170/5774/sig2uq.jpg' border='0' alt='user posted image' /></a>
Mods: M50 intake manifold, BFP CAI, Fan delete, CDV delete, Clears all around, M contours, Clutch stop, Debaffled exhaust, CF BMW emblems
Silverstreak is offline   Reply With Quote
Old 02-25-2005, 12:08 PM   #4 (permalink)
93 325i's Avatar
you may have lifetime fluids. Check the label on the tranny and it will tell you
Complete mod list and pics:
My 1993 325i
Old 02-25-2005, 12:18 PM   #5 (permalink)
[snapback]299222[/snapback]
Is the Mobil 1 synthetic? I run Mobil 1 in my engine and wanted to switch to a synthetic if it was available for transmissions...
~Mark Robert~
Old 02-25-2005, 06:52 PM   #6 (permalink)
jshearer's Avatar
Car: 1994 325is
jshearer is an unknown quantity at this point
All trans fluid are not the same and i have had some problems with my transmission to prove it.
I changed the fluid to Redline Manual trans fluid which is a great fluid but too thick for our cars when it is cold out. My car did not like going into 2nd gear and would grind every once and a while. BMW's use ATF in both Auto and 5 speed cars. I have sinced switched back to Redline ATF and it runs fine. Redline brand is supposed to be one of the best.
Moral of the story make sure you get ATF, and a high quality fluid.
<a href="http://imageshack.us"><img src="http://img217.imageshack.us/img217/3466/quicksignature20te.jpg" border="0" width="600" alt="Image Hosted by ImageShack.us" /></a>
jshearer is offline   Reply With Quote
Old 02-25-2005, 09:06 PM   #7 (permalink)
CiscoKid's Avatar
i would reccomend Mobil1 ATF
Where can I get Shell LA 2634 Tranny Fluid jazzbass 5-Series (E12,E28, E34, E39, E60) 1 10-07-2005 08:09 PM
Tranny Fluid Level Check Beanster 3-Series (E36) 3 05-31-2005 09:12 PM
When to change "lifetime" tranny fluid LloydM 3-Series (E36) 9 08-31-2004 03:38 PM
manual tranny fluid nycbmw325is Bimmer Talk/Motorsports Talk 1 08-09-2004 04:16 PM
Just changed my own tranny fluid Autotechnica 3-Series (E36) 7 04-30-2004 09:15 AM
