Originally posted by Tochenzo@May 15 2005, 09:01 PM if everything is plugged in right, try disconnecting your battery and then connecting it back in [snapback]344797[/snapback] |
Keep in mind, this will cause your head unit to go into security mode and refuse to work until you enter the security code.
Check your ABS sensors too if all else fails.
