tracking down a clutch problem... - BMW Forum - BimmerWerkz.com
Old 10-18-2006, 11:05 PM   #1 (permalink)
berbes is an unknown quantity at this point
back in may, i went out to the car ('95 325i which i swapped out auto for manual summer '05), and the clutch went right down to the floor. thru posting here and elsewhere, it seemed the best bet was the slave cylinder. i ordered the part, meanwhile i added brake fluid, pumped, pumped, added more fluid, pump, pump, etc. until i got the pedal back. i never installed the slave, as i never had another problem with the pedal, plus i didn't notice any fluid on the driveway.
i drove the car everyday until i just went out of town this weekend for 4 days. came back, and i lost maybe 70% of the pedal. had to do the drill again, just not as bad.
what could possibly be the problem? a small, small leak that wasn't apparent until the pedal pressure had the chance to subside by sitting a while?
leaks are not apparent, but i know that means nothing.
ideas?
thanks, guys!
berbes is offline   Reply With Quote
Old 10-23-2006, 02:21 PM   #2 (permalink)
Hydraulic clutches can take in air without leaking and I would always change the master and the slave as a pair, because if you change one it will increase the pressure on the other and very often blow it.
Is This A Clutch Problem? frank3 3-Series (E36) 18 05-15-2012 12:01 AM
Clutch Problem Possibly? Saukk 3-Series (E46, E90) 7 08-27-2005 05:30 PM
1983 325E clutch problem will1506 3-Series (E21, E30) 2 08-05-2003 02:12 PM
