| You have to go to each section of the manual for the specs. Ex. if you want torque specs for the oil filter go to the oil change section of the manual. Be forwarned though, I've found a few errors with the bentley, namely the electrical wire color labels for the radio harness, and the torque specs for the drain plug. Bentley said 18 ft/lbs, I torqued it to 18 and the threads on the drain plug went to shit (It was damn tight and I had never torqued a drain plug that tight before). The only other explanation I have is that my wrench was broke, but highly unlikley.
__________________ 1994 325is M-Technic |
