Timing Chain Or Belt? - BMW Forum - BimmerWerkz.com
post #1 of 4 (permalink) Old 05-05-2005, 08:10 AM Thread Starter
bmwpip is an unknown quantity at this point
Thumbs up
An easy one guys .... how do I tell if my car has a timing chain or timing belt?
I looked it up on the internet, but it says BMW changed over to chains in 1994.
My car is a '1994' 318is coupe (m42 or m43 I think)
Cheers!
bmwpip is offline
post #2 of 4 (permalink) Old 05-05-2005, 08:18 AM
ILiveToRide is an unknown quantity at this point
M42, M44 and M43 have chains.
That means all 16V E36's has chain.
And 318i's 8V from 94.
Or wait, did you in the US ever get the M40 engine?
All 318is (unless the s denotes coupe) have timing chain.
EDIT: M42 and M44 engines are 16V DOHC engines. And M40 and M43 are 8V SOHC engines. The first two in 318is and the latter two in 316i and 318i.
<img src='
1994 Arcticsilber M3, 286hp, 18&quot; AC Schnitzer wheels.
ILiveToRide is offline
post #3 of 4 (permalink) Old 05-05-2005, 11:09 AM Thread Starter
Thanks for the info.
After a bit more research I found out it is the DOHC 16V M42 B18 engine
So now I know it's a timing chain ... phew!
Do these ever need changing? I assume they should be checked for tension/wear?
Thanks again!
Phil.
bmwpip is offline
post #4 of 4 (permalink) Old 05-05-2005, 05:52 PM
Thanks again!
Phil.
[snapback]341085[/snapback]
Yes checking them sometime is good idea. But normally they don't have to be replaced. Get's real nasty when they do break however.
They aren't terribly expensive, so changing them when it's apart for changing the guides etc when it's starting to reach high miles could be an idea.
I had a M42 with 16kmiles on it and the chain seemed fine when I took it apart to change head gasket. That is in a pretty demanding climate.
<img src='
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 04:44 PM
Timing Chain Cover Removal (e36 M3) Jams6502 M-Series (M1, M3, M5, M6) 3 10-06-2004 05:35 PM
Timing Belt or Chain akbarz 3-Series (E46, E90) 1 08-20-2004 06:22 PM
timing belt or chain AutoFan 3-Series (E36) 4 03-07-2004 07:06 PM
1994 318i has a timing belt or chain? jp_bmw 3-Series (E36) 2 09-30-2003 12:53 AM
