Thumping noise from rear - BMW Forum - BimmerWerkz.com
Old 10-20-2005, 02:16 PM   #1 (permalink)
bmw325ise is on a distinguished road
I have recently been experiencing a banging noise from the rear of the car when changing into 1st, 2nd and sometimes reverse, the noise is worse when the car is at a stand still. I took the car to a $tealer today and they came up with the following:
1) the proshaft coupling rubber has perished(or braking up) i presume this is also known as the flex disk?
is this a likely cause? i need some advice as i wanna get this fixed by a local mechanic .
I am also experiencing a lot of vibrations thruough the accelerator pedal , does anyone know what this could be ?
any advice is much appreciated.
1992 BMW 325i SE
Thanks,
Andy
bmw325ise is offline   Reply With Quote
Old 10-20-2005, 04:24 PM   #2 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
Yea sounds right. You can check it yourself. Go under the car, and look just behind the transmission. It's the disc that connects the tranny to the driveshaft.
Dudesky_E36 is offline   Reply With Quote
Old 10-23-2005, 08:57 AM   #3 (permalink)
Yes it’s a common enough fault and it’ll cause the vibration
Old 10-23-2005, 10:04 AM   #4 (permalink)
BImmerN2B's Avatar
BImmerN2B is an unknown quantity at this point
It should be called the Guibo disk
BImmerN2B is offline   Reply With Quote
Rear suspension noise (not shock mounts) Hogfisch 3-Series (E36) 9 02-01-2011 11:04 PM
Rear Brake Noise FoxMill M3 3-Series (E46, E90) 5 08-11-2005 03:41 PM
Rear Road Noise, Noise Gets Lauder As You Go Faste victorgallas 3-Series (E36) 17 01-29-2005 04:05 PM
thumping noise hjj 3-Series (E36) 2 09-08-2004 01:01 AM
