Throttle Body cleaning - BMW Forum - BimmerWerkz.com
Old 07-21-2004, 01:08 PM   #1 (permalink)
Kevin325i's Avatar
So since nobody properly mentioned how to clean the throttle body I'm starting this thread so somebody can tell everyone how. I personally don't, I just assume you spray some alcohol in there and wipe the crap off the butterfly and everything else. I'm not sure and would like to find out however.
Somebody explain the procedure for cleaning the throttle body please.
Kevin
Kevin (President TBEA)
Old 07-21-2004, 01:36 PM   #2 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
I take a can of b-12 chemtool and hold the butterfly open...
Spray liberally, and use a rag to wipe up the crud that comes out. Then, action the butterfly a couple of times while spraying the chemtool onto the axis points of the butterfly. Put all the lines back on it, and start the engine to burn off any excess chemtool. Good as new!
If somebody has a better way, let me know.
kestrel325is is offline   Reply With Quote
Old 07-21-2004, 01:37 PM   #3 (permalink)
Kevin325i's Avatar
Thank you for somebody finally giving a definete answer to everyone.
Old 07-21-2004, 04:41 PM   #4 (permalink)
Robdrmer1016's Avatar
Robdrmer1016 is an unknown quantity at this point
yes thank you very much, i didn't want to sound like a pain to keep bumping that thread
<img src='http://www.bmw-forums.com/forum/uploads/photo-3078.jpg' border='0' alt='user posted image' />
'93 325i 5 Speed
-Clutch Stop
-Window Tint
-2 12&quot; MTX subs
-Debaffled Airbox
-16&quot; Double Spoke Rims
-OEM Clear Corners and Tails
Robdrmer1016 is offline   Reply With Quote
Old 07-21-2004, 05:58 PM   #5 (permalink)
No problem. I used to do this once a year on my old S13. The throttle body was probably the cleanest part on the engine... :lol:
Old 07-21-2004, 08:46 PM   #6 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
i did this today to my moms volvo, i used stp throttle body cleaner that i got at autozone.
i sprayed it in the throttle body itself with the valve closed and cleaned the outside area of the valve, then i sprayed it onto a clean rag and used my finger to push the valve open then i cleaned the area on the other side of the valve (where the seal between the throttle body walls and valve meet), and the other side of the valve itself.
it made a HUGE difference
it was dirty as shit in there, and now the car runs fucking unbeleivably..i have 1000 more rpm's in all gears, it doesnt wind out as quickly, the engine isnt working as hard, and the manual shifting is much much smoother while accelerating, it accelerates much more quickly, and sounds better too.
i wouldnt expect these results though if your car is maintained well, not that my mothers isnt..its jsut that no one ever cleaned the throttle body before
(i also sprayed compressed air through the air filter and cleaned out the airbox..there were leaves in it lol.)
catalyst. is offline   Reply With Quote
M3 Throttle Body On 94 325is 325is1994 3-Series (E36) 4 01-10-2005 10:06 PM
? M3 throttle body on 92 325is fit steve 92 325is 3-Series (E36) 9 07-25-2004 02:56 AM
Throttle Body Cleaning leobmw 3-Series (E36) 0 07-23-2004 11:36 AM
Throttle Body Cleaning??? Rookie 3-Series (E36) 18 07-20-2004 05:38 PM
Boring Out Throttle Body and Heads WickedBimmer 3-Series (E36) 9 03-27-2004 10:26 AM
