Throttle Body - BMW Forum - BimmerWerkz.com
Old 11-11-2004, 08:53 AM   #1 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
sup fellaz,
heard that the throttle body can increase response, so im thinkin of either tuning it or getting the dinan one...has anyone experimented with this? if so, how hard is it to tune? or would i be better off getting the Dinan one...thanks....
Old 11-11-2004, 02:33 PM   #2 (permalink)
Originally posted by SpeedInfusion@Nov 11 2004, 08:53 AM
sup fellaz,
[snapback]228611[/snapback]
Dinan doesn't make throttle bodies. What they do is take your existing one and bore it out to a larger diameter, then replace the butterfly plate with a larger one. There wouldn't be anything to tune really. You would have to increase the diameter of the intake ports and intake manifold then match the throttle body diameter to the manifold. Even that wouldn't do anything, you have to get the right cams to allow more air to flow through the whole system, otherwise you're wasting money on mods. Figure out what the bottleneck on your engine is. If it's airflow restriction (starving the engine), then you should consider those mods.
Typically, the larger plate is bored anywhere from 2-3.5mm. Dinan bores out the throttle bodies + 2.5mm (325) and 3mm (318). Just get a machine shop to do it for you and provide those specs.
I suspect a maximum addition of 2HP gain with an intake, if any gain at all. I wouldn't spend more than $200 on this modification. If you need someone to do it for you, my machine shop charges $150 flat rate for this process. Dinan charges $450 which is outrageous! It's a very simply process. Matching the butterfly plates can be tricky.
Bry
Old 11-11-2004, 05:01 PM   #3 (permalink)
In my oppinion, it's on of the last engine mods you should make. As stated above, the TB is not the most restrictive part of the intake air flow, the manifold is.
Save your money and put it towards another mod.
Throttle Body Air Getting In Sound (whistle) coolkolb 5-Series (E12,E28, E34, E39, E60) 2 05-13-2005 11:24 PM
? M3 throttle body on 92 325is fit steve 92 325is 3-Series (E36) 9 07-25-2004 02:56 AM
Throttle Body cleaning Kevin325i 3-Series (E36) 5 07-21-2004 08:46 PM
Throttle body size? Zq-8_dawg 3-Series (E36) 2 04-27-2004 06:35 PM
Boring Out Throttle Body and Heads WickedBimmer 3-Series (E36) 9 03-27-2004 10:26 AM
