Thicker Head Gasket Lower Compression For Turbo? - BMW Forum - BimmerWerkz.com
Old 01-06-2005, 11:36 AM   #1 (permalink)
Brendan430 is an unknown quantity at this point
Can i lower my compression a little bit by using a thicker head gasket on my 92 325is? because i dont want to buy new pistons for the turbo im getting. Stock setting my the turbo is 6psi. I weould like 7psi maybe 8psi..possible/?
thanks, brendan
Brendan430 is offline   Reply With Quote
Old 01-06-2005, 11:45 AM   #2 (permalink)
SinSeven's Avatar
SinSeven is an unknown quantity at this point
i did that on my acura when i turbocharged it. It worked pretty well. Good for scratch built turbo. BUT.....i am really not sure if this would work for German vehicles. Theory is the same, but not sure......
Hope someone can give you the answer.
SinSeven is offline   Reply With Quote
Old 01-06-2005, 08:47 PM   #3 (permalink)
e36_m3_Turbo's Avatar
yes it will lower the compression with a thicker head gasket
No longer red.
Old 01-06-2005, 09:00 PM   #4 (permalink)
Kevin325i's Avatar
8 psi and you should be fine.
Anything over that and you should start looking into a 3mm head gasket.
Kevin (President TBEA)
Blown Head Gasket? sirmj 3-Series (E36) 6 01-09-2013 08:21 PM
Blown Head, Or Head Gasket? mike11787 3-Series (E36) 4 08-27-2005 07:34 PM
Project: Head Gasket nookatee 3-Series (E36) 1 06-01-2005 10:16 AM
Blown head gasket, new motor or new gasket? Bmw528i 5-Series (E12,E28, E34, E39, E60) 9 07-07-2004 01:06 AM
Head Gasket Rainman66 3-Series (E21, E30) 2 07-18-2003 01:39 PM
