Thermostat Installed Upside Down, Maybe? - BMW Forum - BimmerWerkz.com
Old 12-09-2004, 12:34 PM   #1 (permalink)
YoungExec728 is an unknown quantity at this point
OK. So a few weeks ago I did the fan delete, installed a new water pump, underdrive pullies, and flushed my radiator. I also installed a new aluminmun thermostat housing. I did all this at about midnight in the cold so I was a little careless. When i installed the new thermostat for the fan delete i didn't take note of how it is supposed to be installed, i just put it in there and replaced the housing. A few days later I come to find out that that is an arrow on the thermostat that is supposed to be pointing upwards to allow for correct opening and closing.
So far everything has been running perfectly. No overheating and the thermostat is opening and closing keeping the engine running at optimum temperature. I know this because my previous thermostat was busted and always stayed open and my engine temp would fluctuate up and down with the ambient temp and speed. My only hesitation on opening it back up and making sure it is correctly set is I have to drain my entire coolant system again, which means $20 for BMW coolant and $20 for water wetter. Do you guys think i really need to do this if i haven't had any problems thus far?
<img src='http://memimage.cardomain.net/member_images/9/web/741000-741999/741934_9_full.jpg' border='0' alt='user posted image' />
JC Chip * Cosmos Racing CAI * UUC System U * UUC Underdrive Pulleys * Fan Delete * UUC Sachs Stage 4 Suspension * Sway Barbarians * Racing Dynamics Front strut bar * X-Brace * Front Camber Plates * UUC TME * BBS 18x8.5 * 235/40/18 Yokohama AVS Sport * F&amp;R Zimmerman X-Drilled Rotors * SS Brake Lines * Rouge RSM w/enforcers * Clears all around * SilverStars * Pioneer Avic N-1 * Pioneer 6 Disc Changer * JL 450/4 and 1000/1 Amplifiers * 2 JL 12&quot; W6V2 * Diamond Audio Hexs 6.5&quot; in kick panel * MB Quart Premiums 4&quot; in Rear * Infinity Kappa 3.5&quot; in door * Batcap 400 * Optima Yellow Top
YoungExec728 is offline   Reply With Quote
Old 12-09-2004, 12:42 PM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Dont fix what is not broke.
Easy rule,
It sounds like your careless act might have done it right... I wouldnt worry about it... if she is running at the right temp and things seem to be going well.. then your fine.. not fix required.
Les
1997 E36 M3 1990 E30 325i
Old 12-09-2004, 03:15 PM   #3 (permalink)
ex owner/admin
Furious's Avatar
you probabaly got it right. i wouldnt worry, but if you have time to kill, why not check. cant see the harm
Transmission cooler Thermostat? Laker 3-Series (E36) 5 02-27-2009 01:36 PM
Thermostat Housing Removal E34 M20 Engine 520i tstolber 5-Series (E12,E28, E34, E39, E60) 2 05-23-2005 04:11 PM
Thermostat Replacement Question bmw325ci 3-Series (E46, E90) 1 01-27-2005 02:33 PM
Thermostat Gasket/o-ring? Brian325i 3-Series (E36) 5 10-02-2004 02:30 PM
how to check if Keyless Entry was installed blankdisc 3-Series (E36) 22 06-11-2004 09:00 AM
