Thermostat - BMW Forum - BimmerWerkz.com
Old 02-01-2005, 03:06 PM   #1 (permalink)
JamaC is an unknown quantity at this point
I need to replace the thermostat in my 1997 328i, 79k miles. What temperature rating is stock...88 or 92 deg? Is there anything else I should replace for preventative maintenance while im getting parts and having the coolant drained?
Thanks
James
JamaC is offline   Reply With Quote
Old 02-01-2005, 06:38 PM   #2 (permalink)
billB's Avatar
Depending on how much money you wish to spend! But I would check all hoses and possibly the thermostat housing itself. 92 is stock
good luck
regards
billb
Old 02-02-2005, 01:15 AM   #3 (permalink)
Speedy-325is's Avatar
I use a 78 degree thermostat. its beautiful. i do, however, live in sunny CALI though. in freezing places you may want to stay a bit hotter.
check the water pump
again, the housing. get the aluminunm type if u dont have it.
Mark
Transmission cooler Thermostat? Laker 3-Series (E36) 5 02-27-2009 01:36 PM
Thermostat Housing Removal E34 M20 Engine 520i tstolber 5-Series (E12,E28, E34, E39, E60) 2 05-23-2005 04:11 PM
250 Dollar To Change My Thermostat? sennis 3-Series (E36) 3 02-18-2005 07:11 PM
Thermostat Installed Upside Down, Maybe? YoungExec728 3-Series (E36) 2 12-09-2004 03:15 PM
Thermostat Gasket/o-ring? Brian325i 3-Series (E36) 5 10-02-2004 02:30 PM
