so as some of you may remember i overhauled my cooling system last weekend. So I'm drinv to fedex to pick some stuff up because they can't find my place.... anyways I get there and computer says check coolant level.
So i try turning on the Heat to see if i get any as i heard it was a good test of the system if it blows hot air the thermostat is working... well no hot air warm yes hot no... warm because its 85 out. The temp gauge doesn't /hasn't made it past the half way point.
I get home, pop the hood coolant looks low. I open it (i know i shouldn't when the eninge is hot and fluid spills out the top of it.) which brings me here...
Ideas? re replace thermostat? take it out and put it back once things cool down?
Did you rev the engine while you put the coolant in with the heat on high? You probably just have an air bubble in the heater core. Oh and it sounds stupid, but did you turn the little dial on the middle vent to the red? I assume you did
Kevin
Start it up open the cap, and the little air screw. Then poor coolant in while somebody has the heat on high and revs the engine. If it were a bad thermostat you'd probably have more problems or your needle will take FOREVER to get to the middle.
Kevin
Originally posted by steve 92 325is@Jul 2 2004, 08:40 AM I had the same problem after changing my thermostat 2 weeks ago It was an air bubble I had to blled it 2-3x's after chagning it
blled?
EDIT: did you mean Bleed? it took me a sec to figure it out...
