| not neccesarily.. The flywheel shouldn't need replacing at 99,000 miles in most cases.. And if you consider a lightend flywheel be carefull as the weight of the flywheel is what keeps the car at idle.... i.e. getting too light of a flywheel causes the car not idle as well or if at all, where you have to end up adjusting the idler screw so the car idles at a higher RPM...
FOUNDER of the BMW-Forums Michigan Club <span style='color:green'><a href='http://www.cardomain.com/memberpage/458339' target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1078289877.jpg' border='0' alt='user posted image' /> |
