Temporarily losing power, RPM jump - BMW Forum - BimmerWerkz.com
post #1 of 16 (permalink) Old 03-05-2004, 11:34 AM Thread Starter
jlb318 is an unknown quantity at this point
Very bizarre situation with my 95 318i...has happened twice in last two months. I'll be driving along fine, and then go to change gears and the car will briefly (split second) loose all power (steering, radio will fuzz out for a second, guages will light), and then get it back and drive fine. The RPM's jump up during this instant too. Car doesn't die altogether, it's like it just hits some type of glitch.
I'm worried that this problem might get worse, or that it may occur during a time when it could put me in danger.
Does anyone know what this could be?
jlb318 is offline
post #2 of 16 (permalink) Old 03-05-2004, 11:41 AM
Defector
El Presidente's Avatar
was it raining when this happened?
Im going to guess either water in the ECU or o2 sensor
El Presidente is offline
post #3 of 16 (permalink) Old 03-05-2004, 11:49 AM Thread Starter
No, wasn't raining either time...temp varied from 20 degrees the first time to mid 40's the second time.
jlb318 is offline
post #4 of 16 (permalink) Old 03-05-2004, 11:58 AM
Defector
check your o2 sensor, battery's charge, and alternator.
post #5 of 16 (permalink) Old 03-05-2004, 12:08 PM Thread Starter
Will do, thanks for the direction!
jlb318 is offline
post #6 of 16 (permalink) Old 03-05-2004, 07:59 PM
been in a car when the alternator died. the gagues and lights just all sorta faded and died the car only when a little while longer then died....
I'd check wires too. be sure nothing is loose causeing a tempoary disconnect and causing things to fade/jump/fuzz etc...
2008 128i Jetblack
007ben is offline
post #7 of 16 (permalink) Old 03-05-2004, 09:39 PM
breakpopin's Avatar
breakpopin is an unknown quantity at this point
I think its the alternator too!.. It may be faulty and causing intermitten problems.
update us on your case dude
<img src='
breakpopin is offline
post #8 of 16 (permalink) Old 03-05-2004, 09:44 PM
bimmerfan620's Avatar
bimmerfan620 is an unknown quantity at this point
Send a message via AIM to bimmerfan620 Send a message via Yahoo to bimmerfan620
I don't think this is your alternator problem.. Although I might be wrong, I don't think the symptoms are of an alternator. Although to knock out the Alternator, I would do a check on alternator itself with a multi-tester..
FOUNDER of the BMW-Forums Michigan Club
<span style='color:green'><a href='
target='_blank'> Car Domain UNFINISHED </a> </span>
<img src='
bimmerfan620 is offline
post #9 of 16 (permalink) Old 03-05-2004, 10:30 PM
even if it isn't the alternator it's most likely electrical. if its not the alternator it may become more of a pain to find the source of the problem
2008 128i Jetblack
007ben is offline
post #10 of 16 (permalink) Old 03-07-2004, 09:59 AM
fernguy is an unknown quantity at this point
jlb318 I think your problem is actually your ignition switch. What you might try is to lift your keys up and down while you are driving. Don’t rotate the key because you might accidently lock the steering wheel while driving and cause a accident. But lift vertically up and down and if your glitch reoccurs then you have your problem. What prematurely wears out the ignition locks & ignition switches is the weight of a heavy key set. Meaning too many keys on the key chain. A suggestion to anybody reading if they are doing this it is better to get a quick disconnect key chain and only have the ignition key by its self when operating their vehicle.
Hope this helps
fernguy is offline
post #11 of 16 (permalink) Old 03-07-2004, 10:48 AM
EXtech's Avatar
I would have to agree with fernguy. That would actually be the first place that I would look. I have seen that happen several times. If the ignition switch is not your problem then I would begin my focus towards the DME and it's connectors. The E36 has the potential to gather moisture and condensation in the cavity where the dme is stored. I have also seen connectors work themselves loose. However, I believe that you will find your problems within your ignition switch.
fernguy... are you a tech or have you just experienced this problem with your own car??
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
STETT Performance Official Grand Opening BMW Meet, May 6th 11A-3P -- Music, Food, Drawings and Tons of BMW's go to
and register.. it's FREE
EXtech is offline
post #12 of 16 (permalink) Old 03-07-2004, 12:48 PM
EXtech to answer yes your question I am a automotive tech.
fernguy is offline
post #13 of 16 (permalink) Old 03-08-2004, 07:57 AM
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
my 92 325i used to do the exact same thing, I would be driving and then all the sudden i would lose all power, then I would floor the gas then all the sudden it would kick back in and take off...In the end, all 6 of my connectors to my spark plugs were corroded badly and was also causing my car to sputter...You may want to have that checked....That fixed all my problems!
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline
post #14 of 16 (permalink) Old 03-08-2004, 04:56 PM Thread Starter
Thanks to all who have replied...the ignition switch could very well be the problem, as I've noticed other problems with that in the past, which I thought were totally separate and unrelated. For instance, sometimes when I go to start the car, I insert the key and turn it, and it doesn't catch on anything. I can literally spin the key a full revolution without starting the car.
Does this make sense?
jlb318 is offline
post #15 of 16 (permalink) Old 03-08-2004, 07:55 PM
jlb318 Now there is a difference between a ignition switch and ignition lock.The ignition switch actually is mounted directly behind the iginition lock. The ignition lock is the part that the key inserts into.And yes that is okay for the lock to spin when the key is not inserted properly it is part of the theft-deterrent feature of the car.The ignition switch is a electrical component that is mount directly behind the ignition lock that actually moves in conjunction with the lock to supply electrical service to the vehicle at a given point of its rotation. I thought I should make this point more clear.
Hope this helps.
fernguy is offline
Mini Cooper S Losing Power Pantalaimon 1,6,7,8 - Series and Mini Cooper 3 03-10-2005 05:34 PM
Best Kind Of Headlight Bulb? all4isu 5-Series (E12,E28, E34, E39, E60) 6 10-18-2004 02:26 PM
losing power / Air flow Noise when accelerating Gaizeh 5-Series (E12,E28, E34, E39, E60) 0 07-25-2004 12:12 PM
power pulleys, re they really that bad? the///man 3-Series (E36) 1 10-18-2003 09:12 AM
