1995 325is with 235 000 Kms. Rad and temperature gauge were changed at dealer in April 2005 along with waterpump. Coolant level is fine.
When sitting car warms up to 50% or mid-point between blue and red on the gauge. Once you start driving the temperature dips back into the blue (cold).
Checked the sending and returning hoses to the heater core and they're hot. Some heat does come through the heating vents but very little compared to what it used to do. HVAC system works fine.
I picked up the car in May so I wouldn't know if this was a problem last year and I can't reach the previous owner.
Does anyone have any idea what's going on?
Don't want to go through a Montreal winter without heat.
thanks. e36surge
__________________ "If everything seems under control, you're just not going fast enough."
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
ok well i put 2 and 2 together... i found the thermostat on bavauto.. and found the DIY in the betley manual... i just wanted to know if i gotta buy the thermostat housing aswell?
You don't have to unless you want to upgrade to alluminum one which will prevent the cracking from the cheap plastic one.
I forgot, have you checked for leaks?
__________________ - 97 M52 Beast - Vortech V-1 Supercharger Setup - Dinan Software - 28.8lb Injectors - 9psi - ZKW's - OEM Clears - DoubleSpoke II's - OEM M3 Spoiler - OEM M3 Front Bumper - 20% Tint - CCFL Angel Eyes - 6K Xtec HIDs in ZKWs - 6k H1 based D2S HID's in Foglights - Bilstein Sport Shocks - Eibach Sportline Springs - Cosmos Racing CAI - M50 Manifold Swap - UUC Motorwerks SystemU Exhaust - Fan Delete - 3.15 LSD -
but i had the same problem on my accord and i found that the lever was semi-jammed in the engine and i had to grease the end of it so that when i rotated the blower switch it would actually open up all the way
__________________ '85 325e
'Arrest Me Red'
mods to come:
Window Tint
New Badges - Check!
Muffler - Check! - Ansa free flow
New Radio
Sport Shocks - Bilstein
Keyless Entry + Alarm - BMW Security Systems
Power Flow Intake
Yeah, I would say thermostat. I did mine recently. I had the same symptoms. Quick job, but you need to take the fan off. If you didn't ask them to change the thermostat, they might not have. I didn't bother with the aluminum housing. The thermostat I got looked different than what was in it, so don't be alarmed.
The thermostat in my bosses new X5 failed before it reached 2 years old or so.
