TECH QUESTION HELP - BMW Forum - BimmerWerkz.com
Old 05-19-2004, 11:07 AM   #1 (permalink)
sil325i is an unknown quantity at this point
A few days ago, my Brake Circuit Light came up on the Digital LCD screen. In the owners manual it said that the brake fluid might be low, but i checked it and it was still good, the fuse might be bad, but it was good too. the brakes work just fine. has anyone else had this problem? i'm thinking there is short on the electrical brake sensors which is causing it to pop up every now and then...?? Help
sil325i is offline   Reply With Quote
Old 05-19-2004, 11:22 AM   #2 (permalink)
Car: 2008 128i
the brake light switch has been known to fail and cause this problem from time to time too..
I belive there is a FAQ.
2008 128i Jetblack
Old 05-19-2004, 12:45 PM   #3 (permalink)
Super Moderator
dutchbmw's Avatar
When the brake pads comes to the end of life, they warn you: REPLACE ME, REPLACE ME, REPLACE ME........
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 06-02-2004, 02:11 AM   #4 (permalink)
Cary328is is an unknown quantity at this point
Check www.logun.org. This is an awesome site for tech help. Click on E36
Brake Light circuit can mean ANYTHING within the brake system from the actual switch to just being a bulb burned out in the back or a fuse. Check all your brake bulbs to make sure they're working. Then, check logun.org to learn more about the brake switch.
Cary328is is offline   Reply With Quote
Old 06-02-2004, 05:01 PM   #5 (permalink)
Steinkek is an unknown quantity at this point
mine has been doing that to when im am stopping on hills mostly. In my manual is says that one of the brake circuits could be going out. if anyone knows anything else it would be nice to know
Steinkek is offline   Reply With Quote
Old 06-02-2004, 05:14 PM   #6 (permalink)
CiscoKid's Avatar
mine only happens with moisture.... as long as your brake lights are on, your good
Tech Question Shudogg 3-Series (E36) 0 03-03-2005 02:31 PM
Tech Question HI OFCR 5-Series (E12,E28, E34, E39, E60) 2 12-22-2004 06:44 AM
Tech question 1faste30 3-Series (E36) 1 08-23-2004 10:08 AM
Tech Question gotKRAUT 3-Series (E21, E30) 11 08-09-2004 09:01 PM
Question for the TECH Braymond 3-Series (E46, E90) 5 02-27-2004 06:02 PM
