I'm looking at swapping my diff to a LSD. I have a 318i, and I've heard that you can swap in a LSD from a 325i (I believe). If thats the diff that I heard about, at 70 mph in 5th I'd be at 4,200 rpms. Has anyone done this swap? or swapped for a different diff? or does any one know the ratios for the different E36 diffs or other diffs that can be swapped in? Lots of questions I know, but this should be an excelent thing, and really help off the line acceleration, traction but lower top speed (which is fine with me).
You cannot swap a 325 diff in a 318 without also changing the driveshaft. I also was interested in a swap, until I leanred the 325/328 diffs were designed differently than the 4cyl engines' diffs. The lengths are different.
the only diff that would make a difference and would be easy and cheaper is the diff from an auto. Say goodbye to your top speed, but it would make a large impact on acceleration. I wanted a 3.91 for the longest time, but found out the 4.44 was the only one that would work, and those revs are just too high for me.
Also does the whole drive shaft have to be changed or just the rear? I'm still looking into this as a possibility because I'm getting it part and installed in trade for an engine (5sfe from a 92 celica), so as long as the parts would be less than $500 it should be a go.
