TDS 2.5 fuel pump non delivery - BMW Forum - BimmerWerkz.com
Old 07-16-2008, 03:16 PM   #1 (permalink)
moggyroo10 is on a distinguished road
hello, i hope somebody can help me get my new toy on the road. its a 2.5 tds estate. my problems started after i bought the car as a ropey runner, it tried turning over but was hydrauliced, i thought an injector had overfuelled and filled a pot. i left the car for a couple of weeks and when i came back to it the battery was totally flat. with a good charge in the battery the car would not even attempt to start off the key , i was advised that the chipped key had probably lost its memory and would need re setting. on to of this the engine turned out to be totally shot so i have fitted 525 tds engine, the car still wont turn off the key though all ign lights come on. i have swapped the pumps so that it has the 325 pump on but although the pump is sucking deisel it all goes back to tank if i short the starter and spin it over. any ideas please, surely having a flat battery cant mean going to a main dealer which would probably cost more than the car is worth
moggyroo10 is offline   Reply With Quote
Old 07-17-2008, 12:15 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lightbulb
you did not specify the year model of your car, but check the starter and fuel pump relays.
Old 07-17-2008, 12:50 AM   #3 (permalink)
regds for your reply, when the car was stood and the battery went flat it had the key left in the ignition and i have been told by a bmw service manager that this will have wiped the key chip memory and that without a spare key theres not a lot can be done to retrieve the coding
Old 07-17-2008, 04:54 AM   #4 (permalink)
Car: 750il E32
bobwatt is on a distinguished road
moggyroo10
I had a 325TDS at my shop with exactly the same problem. I couldn't get around the problem but someone else is looking at it and if they fix it I will post it. Good luck.
bobwatt is offline   Reply With Quote
Fuel Delivery Issue? dvmotorsports 3-Series (E36) 3 01-27-2006 01:32 PM
Fuel Pump?? woodsy5629 3-Series (E21, E30) 13 09-06-2004 03:41 PM
Fuel Pump raoultesla 3-Series (E21, E30) 2 08-11-2004 01:20 PM
fuel pump? quickmike 3-Series (E21, E30) 6 10-16-2003 10:59 PM
fuel delivery system questions SeatTime 3-Series (E46, E90) 1 10-08-2003 08:29 AM
