tail light and brake light failure - BMW Forum - BimmerWerkz.com
Old 10-20-2008, 12:36 PM   #1 (permalink)
Car: 1998 BMW 328i
smacker is on a distinguished road
Exclamation tail light and brake light failure
i got this message this morning in my check control all all my lights work. i checked the brake lights the turn signals every single tail light they all work fine, anyone know what i can do? or what can cause this?thanks
smacker is offline   Reply With Quote
Old 10-20-2008, 01:16 PM   #2 (permalink)
Steve323i99's Avatar
Car: 99 323i E46, 97 Jeep ZJ larado 5.2L
Steve323i99 is on a distinguished road
I had the same problem on my 323i E46 99, the check light was on and I replaced all the lights and they worked but the check light was still on. What it turned out to be is that the wire harness cable that connects to the light housing; one of the pins was slightly burned and melted. This causes a slight voltage irregularity thrown to the computer telling it there is a fault even though the lights still work. So check all your wire connections very closely and see if you have any abnormalities or burned out pins.
Steve323i99 is offline   Reply With Quote
Old 10-22-2008, 08:16 PM   #3 (permalink)
Car: 1998 BMW 328i
did you replace your connections? or do you just live with the warning light? the pins inside are a little black.
Old 10-23-2008, 10:54 AM   #4 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Hey.....common problem in the e36.....9 times out 10 its the brake switch under the brake pedal.....also aftermarket bulbs.....if you have the slightest break in continuity it will trip the warning but your lights will still work.....make sure all your bulb contacts to the light socket contacts are clean & solid....also check out the wiring harness that is mounted to the driver's side trunk hinge....check out these links
brakeswitch.page
http://www.bimmerwerkz.com/forum/3-s...ing-55136.html
johnny,
Old 10-23-2008, 10:44 PM   #5 (permalink)
Car: 1998 BMW 328i
thanks for those 2 links ill look into my wires tomorrow.
Brake Light Circuit And Tail Light Failure 325is1994 3-Series (E36) 7 08-05-2008 12:00 PM
Tail Light Failure? Cel abemcclellan 3-Series (E36) 3 03-28-2005 11:56 AM
HELP...Tail Light Failure ds16 3-Series (E36) 2 02-25-2004 10:35 AM
Tail light failure bmw_m3power 3-Series (E36) 17 12-17-2003 05:39 PM
After tail-light upgrade, left brake light is gone mostwired 3-Series (E36) 3 11-26-2003 05:13 PM
