Suspension Question - BMW Forum - BimmerWerkz.com
Old 10-15-2004, 01:07 PM   #1 (permalink)
92_325i is an unknown quantity at this point
this may sound stupid and might have been answered before, but i couldnt find everything i needed to know. i've been doing some research on coilovers for the 1992 325i that i just bought, and have yet to find any made for the 92 model year. i searched and found out that this was due to BMw using different strut mounts or something. now, my question is, what is needed to make a set of coilovers work? also, what coilovers do you have or prefer? i want something stiff, very stiff. my passengers can get over it. any help would be great.
<a href='http://www.cardomain.com/id/jordan92bmw325i' target='_blank'>My 1992 325I</a>
<a href='http://www.cardomain.com/memberpage/461648' target='_blank'>My 1989 Nissan 240sx</a>
<a href='http://www.cardomain.com/member_pages/view_page.pl?page_id=724529&cat=10&val=1&page=1' target='_blank'>My girls' 1998 Camaro</a>
92_325i is offline   Reply With Quote
Old 10-15-2004, 02:54 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
not sure about the setup , im sure its the same.... as for suggestions , bilstein PSS9's are awesome and probably my personal pick would be Ground Control coilovers.
Old 10-15-2004, 05:17 PM   #3 (permalink)
Most likely it's because of the tabs on the front struts which the front sway bar mounts to. After 1992 they started mounting the front sway bars to the control arms rather than the struts. So you have a few otions.
1. Get someone to weld some tabs onto the struts for you.
2. Get a front sway bar meant to be mounted to the control arms.
3. Get Shock/spring combo instead of coilovers.
Bry
Old 10-15-2004, 09:10 PM   #4 (permalink)
Bry
[snapback]211879[/snapback]
ok, i like the idea of number 2 there. is there any modifications that need to be done to the control arm then?
Old 10-15-2004, 11:37 PM   #5 (permalink)
Kevin325i's Avatar
5/92 and earlier use a different type of strut mount in the top. Completely different from the sway bar stuff, it's actually a different size of the parts on top of the struts. You need a coversion kit that can be found at like turner and then you just use the coil overs you want.
Kevin (President TBEA)
Old 10-15-2004, 11:44 PM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
If I'm not mistaken they dont have that kit on their web site.. you must call... they should have it though....
Peace
Les
1997 E36 M3 1990 E30 325i
Old 10-16-2004, 09:18 AM   #7 (permalink)
ok...it makes sense now. somewhere i read for H&R coilovers, extra parts were needed for the 92 model and that they were available. i got it. thanks for all of your help.
Suspension Question corbeledg 3-Series (E46, E90) 7 04-13-2005 02:33 PM
Suspension Setup Question shauv M-Series (M1, M3, M5, M6) 2 03-01-2005 02:30 PM
Suspension Question komodo 3-Series (E36) 12 01-23-2005 04:22 AM
Suspension question Turbodefrost 3-Series (E36) 3 07-28-2004 07:20 PM
97 528i suspension question??? tmac2k3 5-Series (E12,E28, E34, E39, E60) 3 07-14-2004 02:35 PM
