Suspension problem. Wheel Bearing? - BMW Forum - BimmerWerkz.com
Old 07-27-2011, 03:01 PM   #1 (permalink)
Destro3 is on a distinguished road
I have a lot of road vibration and noise from the left front wheel. When I slightly turn to the left, like when changing lanes, the ride becomes perfectly smooth. Turning slightly to the right causes it to get only slighty worse. My thoughts are that it could possibly be a wheel bearing but I am no mechanic. Any suggestions? Thank you.
Destro3 is offline   Reply With Quote
Old 07-29-2011, 01:18 AM   #2 (permalink)
/Banned
Car: 99 mustang
Randyboyy is on a distinguished road
Road vibration and noise from the left front wheel have any other problems
Randyboyy is offline   Reply With Quote
Old 07-29-2011, 03:31 PM   #3 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Hmmm... could be a shot bearing... I would go for the Strutt(s) TBH !
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 07-30-2011, 11:55 AM   #4 (permalink)
hemi_fan is on a distinguished road
I had a similar problem and it was the lower ball-joint. Jack up the car and see if the wheel will wriggle. If it does, peek in behind and try to see which part has all the slack, it should be obvious if its a ball-joint or tie-rod end as you will see the hub move but not the joint/rod. If both are solid and it still wriggles it might be your wheel bearing, try spinning it by hand and feeling for resistance/grinding.
hemi_fan is offline   Reply With Quote
Wheel Bearing jayy781 1,6,7,8 - Series and Mini Cooper 3 07-18-2009 02:24 PM
Rear Wheel Bearing CiscoKid 3-Series (E36) 3 05-14-2007 10:39 PM
wheel bearing? bob318 3-Series (E36) 3 02-21-2006 12:15 AM
Wheel bearing screwed Turbodefrost 3-Series (E36) 0 09-06-2004 11:19 PM
Wheel Bearing Question BeemerMan 3-Series (E36) 1 09-06-2004 01:07 PM
