Suspension noise - BMW Forum - BimmerWerkz.com
Old 06-29-2012, 03:58 PM   #1 (permalink)
Car: 1998 BMW 323is
bpwestmoreland is on a distinguished road
Suspension noise
need some help here, my driver rear suspension makes a loud popping noise when I go over a decent bump. I recently did the shocks in the rear, have been told maybe a broken sway bar link, they looked fine, I was thinking a bushing of some kind. Any ideas?
I took measurements of ride heights, they are as follows
DRIVER FRONT 26 1/16
PASSENGER FRONT 26 3/8
DRIVER REAR 25 1/8
PASSENGER REAR 25 1/8
All tires are at specified pressure and 2 brand new in rear and 2 relatively new in the front
bpwestmoreland is offline   Reply With Quote
Old 07-01-2012, 09:10 AM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Check your rear shock mounts. Make sure the bushings aren't worn out.
Click HERE to see my E36 Blog
Old 07-01-2012, 10:14 PM   #3 (permalink)
Car: 1998 BMW 323is
I just replaced everything new, mounts, reinforcing plates, the only thing is I have 1 washer that is different on that side. Do you think something as small as a washer could do all that noise?
Old 07-03-2012, 12:55 PM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
It's possible. Sometimes the littlest things cause the biggest headaches. I think as long as the thickness is the same it shouldn't be an issue.
Old 07-03-2012, 07:29 PM   #5 (permalink)
Car: 1998 BMW 323is
I did not check thickness....
Old 07-03-2012, 09:57 PM   #6 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Are all your bushings original? If yes, you should think about replacing them. The car will drive like It did when new.
Old 07-05-2012, 07:09 PM   #7 (permalink)
Car: 1998 BMW 323is
I believe they are probably original, bought the car used a year ago,
new suspension making noise kholt 3-Series (E36) 4 12-27-2010 07:30 PM
Suspension Noise Help Please Foomp 3-Series (E36) 6 04-09-2010 09:21 PM
Brake or suspension noise? fastshivy M-Series (M1, M3, M5, M6) 6 07-13-2006 03:46 PM
Suspension Noise shield 3-Series (E21, E30) 2 08-19-2004 10:36 AM
front suspension noise sirmj 3-Series (E36) 4 07-02-2004 02:03 PM
