suspension/handling question - BMW Forum - BimmerWerkz.com
Old 04-08-2009, 11:45 AM   #1 (permalink)
328ic98's Avatar
Car: 1998 BMW 328 Ic Cabriolet
328ic98 is on a distinguished road
Question: This car is new to me- so i can't compare with past performance, but when you hit bumps in the road- the car tends to "float" side to side. Could this be a torsion bar, bushings?? I just had a mechanical inspection, and passed with no problem. Any idea what ishould be looking into?
328ic98 is offline   Reply With Quote
Old 04-08-2009, 12:09 PM   #2 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
sounds like your suspension is dead. shouldnt be floating around when you hit bumps
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 04-08-2009, 01:02 PM   #3 (permalink)
A torsion bar, or twist beam is a semi independent rear suspension for front wheel drive cars. (It consists of trailing arms with the torsion beam running between a short distance back from the pivot point). BMW's have, of course, rear wheel drive with multi link, independent back suspension. If this is happening in the back, I'd have a look at the trailing arm and any lateral arm bushings. If it's the front, I'd start with the lower control arm bushings.
Old 04-08-2009, 06:13 PM   #4 (permalink)
Ich bin der Modifikator
johnnyBgood's Avatar
Sounds like the rear trailing arm bushings are shot.....this is what happen with my car, whenever I hit bumps the rear end of my car would shift side to side....found this link & replaced the RTAB's & problem was solved....
Symptoms of bad trailing arm bushings include side movement of the rear end under acceleration, general looseness of the rear over bumps, and abnormal tire wear. These bushings will start wearing out after about 50,000mi, give or take. As you'll see in this DIY, I made a special puller/press tool for dealing with this stubborn bushing, but it wasn't good enough for removal. So I had to go butcher style, which is an option many choose instead of paying out your ass for the tool
BMW E36 RTAB Without Special Tools
E36 RTAB DIY with BMW Tools w/ or w/o GC shims - Bimmerforums - The Ultimate BMW Forum
johnny,
Old 04-08-2009, 06:26 PM   #5 (permalink)
328ic98's Avatar
Thanks great info! Definately on my list of things to do!
Old 04-08-2009, 07:03 PM   #6 (permalink)
Sodium Chloride
saltshaker185's Avatar
Car: 95 M3
also i would look in your trunk at your rear strut mounts. ive seen similar instances where cars would hop to one side when they hit bumps because they mounts were punched through and there was no dampening on one side of the car...
Old 04-08-2009, 08:54 PM   #7 (permalink)
Science Roolz!
Car: 2011 Mazda2, 1990 Miata
could be totally blown shocks as well
2011 Mazda2
1990 Mazda Miata
Suspension Adjustments for Handling SpeedInfusion 3-Series (E36) 18 01-06-2011 07:16 AM
Suspension Question corbeledg 3-Series (E46, E90) 7 04-13-2005 02:33 PM
Suspension Question komodo 3-Series (E36) 12 01-23-2005 04:22 AM
Suspension question Turbodefrost 3-Series (E36) 3 07-28-2004 07:20 PM
another suspension question Furious 3-Series (E36) 4 04-20-2004 11:12 PM
