Sunroof Problems!!! Help - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 01-25-2004, 09:52 PM Thread Starter
SiR325i's Avatar
SiR325i is an unknown quantity at this point
Has anyone experienced the sunroof only going halfway up, and then stopping? I can't close it or open it from this position. It seems like there is something jammed inbetween the tracks or the motor isn't turning...!?!?! If anyone has had this problem, please give some advice...
SiR325i is offline
post #2 of 5 (permalink) Old 01-25-2004, 10:13 PM
TECH's Avatar
Try holding the button up for about 10 seconds. This should initialize it-it may move up a little to indicate that it worked.
TECH is offline
post #3 of 5 (permalink) Old 01-25-2004, 10:29 PM Thread Starter
SiR325i's Avatar
thanks..it helped a little, but it is not fully closed, about 1 inch away.!! do you think it could be the comfort relay? this is what other forums are saying, but my 4 windows are working, it's just the sunroof..?
SiR325i is offline
post #4 of 5 (permalink) Old 01-26-2004, 01:15 AM
TECH's Avatar
What's a comfort relay? :P
Your cassette may be binding. They can be repaired, depending on what is wrong or course. You can replaced the sliders, but they are a major pain. I wouldn't recommend doing it yourself.
That might be your problem. Maybe you could open it up and inspect, lube, clean the rails and sliders, etc. Then it may not shut.......so.........
There may be a manual handle in your tool kit in the trunk, which should allow you to manually move the cassette, to override the motor. It will either fit into the motor, like a hex bit, or the motor should be removed and the tool used instead...one or the other, if you have a tool at all.
TECH is offline
post #5 of 5 (permalink) Old 01-26-2004, 11:11 AM Thread Starter
SiR325i's Avatar
Yeah...I've tried using the tool, but it won't close all the way...oh well, i'll just get it fixed at the dealership..DAMN! Thanks for the help.
SiR325i is offline
Electrical, Sunroof, Interior, & Opinion Issues '92 325i Alpine 3-Series (E36) 1 08-10-2005 05:12 PM
Roof Rattles A Bit. Sunroof Issue? ynotony 3-Series (E36) 4 07-18-2005 09:41 PM
Sunroof Issue bmwfool 3-Series (E36) 4 05-18-2005 12:42 AM
Sunroof Noises Caused By Vibration. victorgallas 3-Series (E36) 0 01-20-2005 03:27 PM
sunroof problem? help!!! pherbolario 5-Series (E12,E28, E34, E39, E60) 4 12-30-2004 05:57 AM
