See if this cures your window problem. Get in the car, close the door, turn the ignition on and press and hold the window switch in the up position until u hear a clunk and then let go. Then do the same again, this time holding the down position. Might wanna try this a couple of times...
If that doesn't cure the problem, u might wanna get the drivers door latch looked at...
Good luck...
