Sunroof Issue - BMW Forum - BimmerWerkz.com
Closed Thread
Old 06-07-2005, 12:06 PM   #1 (permalink)
bpowers's Avatar
bpowers is an unknown quantity at this point
Having difficulty with sunroof -- When I operate, it does move, but stops sometimes (motor continues to run). I hear a clicking like noise (like a plastic piece keeps spinning and hitting somthing). Also, the headliner area in the front part of the car is being pushed down -- hard enough to push out the visor lights (broke driver's side buld and holder), and I can no loger keep sunroof console cover on as that area is being pushed down as well. Roof can still tilt up but no longer slides back. I took roof off and it does not look like any of the track pieces are broken. Any ideas? ('96 318ti)
bpowers is offline
Old 06-07-2005, 12:59 PM   #2 (permalink)
e36surge's Avatar
http://www.bimmerdiy.com/diy/e36sunroof
http://www.fastlanebmw.com/sunroof/tilt.htm
"..there is also a way to open and close the sunroof manually in emergencies. you pop off the top cover where the button is to open it, it's in you owners manual." (taken from another thread)
Sounds like your snroof motor may have moved as well... Check the first link.
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
e36surge is offline
Old 06-07-2005, 05:18 PM   #3 (permalink)
bpowers's Avatar
[snapback]351542[/snapback]
Thanks, surge. I've looked at both those sites before, and I actually ordered the parts, but the lifters and other plastic parts look fine upon close inspection -- a little hard to move, so I greased the rails a little. My problem seems to be related to the wire housings/tubes (?) attached to the motor. They've seem to have moved? After removing the headliner, it seems like those "tubes" are what's pushing the headliner down. Not sure if the gear wire inside has been over-twisted.
bpowers is offline
Old 10-17-2010, 03:18 PM   #4 (permalink)
n1sniper is on a distinguished road
mine just started giving me trouble.. it pops up... it closes... but it wont slide open ?
n1sniper is offline
Old 10-17-2010, 03:22 PM   #5 (permalink)
Might wanna start a new thread; this is from 2005
witeshark is offline
Closed Thread
Roof Rattles A Bit. Sunroof Issue? ynotony 3-Series (E36) 4 07-18-2005 09:41 PM
Sunroof Issue bmwfool 3-Series (E36) 4 05-18-2005 12:42 AM
My Sunroof..... breezd 3-Series (E36) 4 04-15-2005 10:03 PM
Sunroof Noises Caused By Vibration. victorgallas 3-Series (E36) 0 01-20-2005 03:27 PM
sunroof problem? help!!! pherbolario 5-Series (E12,E28, E34, E39, E60) 4 12-30-2004 05:57 AM
