The other issue the car has is a stripped spark plug hole in the #2 plug. has anybody had any luck repairing this? I bought the car with this problem and was hoping for a quick fix I do have another complete motor but wanted to rebuild it before I switched motors was told a heli coil would work and was just curios to see if anybody has tried that before. The car is a 1993 325 IS 5 speed car
Yes, I have had success with spark plug threaded sleeves, not heli-coil but the threaded inserts bought at advance. I do advise that if you take it to a garage that can do this when asked with out hesitation, if they pause, or look at you funny at all, go somewhere else. It doesn't mater if its a BMW or a ford 4.9L v8, the technique is the same.
the exact same thing happended to me. they put a thread sleave on but that blew right out the very next day. i had to get a new head and my timing had to be redone. cost about 4 g's if i remember correctly
If done correctly they won't blow out and are stronger than stock threads. From what you said the garage that you took it to didn't do a good job, and/or used an inferior part.
Let me just clear it. Is the setup the same even with Mazda's. I have a problem with my Mazda spark plug wires and maybe i can use some info from this.
If it takes a spark plug, the technique is the same. Those thread repairs will work on any damaged spark plug threads. However it must be done correctly, or they can back out.
Use anti-seize so you don't have to worry about them sticking and backing out from them rusting together. Actually you should always use anti-seize, the copper stuff is better than the aluminum stuff. (try not to get anti-seize on you, the shiny gunk gets everywhere)
heli coils are a good proven problem solver, id suggest getting someone pro to put it back together for you, it might cost a bit more but its peace of mind.
