Strange Noise... Help!... - BMW Forum - BimmerWerkz.com
Old 06-15-2005, 01:02 PM   #1 (permalink)
M3wannabe2004's Avatar
M3wannabe2004 is an unknown quantity at this point
Hi Guys, I own a '92 325i , all is fine apart from one puzzling noise. It seems to be creaking noise that only occurs when the car is first fired up. With the car in gear and pulling away the car will make a creaking sound, it comes from the rear of the car, it will only do this once , you will not hear a peep from it for the rest of the journey until you switch the engine off and back on again. I have isolated the brakes, tested by parking the car up with the handbrake off, it seems strange that the noise only happens when 1) The car is started (no matter if the car has been running 2 hours, if you swithed the car off and on the noise would occurs) 2) The car has travelled approc 5-10 metres in 1st or 2nd gear. Any pointers on this would be great.
Thanks Guys
M3wannabe2004 is offline   Reply With Quote
Old 06-15-2005, 11:33 PM   #2 (permalink)
thekid's Avatar
hmmm... I'll bump this and ask a question, is the creaking sound coming from the middle left or right side of the back?
Old 06-16-2005, 12:45 AM   #3 (permalink)
[snapback]353973[/snapback]
Hi Mate,
It sounds like it's coming from the left side..
Any Ideas?
Old 06-16-2005, 03:53 AM   #4 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
Thanks Guys
[snapback]353765[/snapback]
Well, what's more unusual is that you don't hear a peep other than that creaking noise.
It's a big ol' machine... I'd bet it's totally normal. Still, it could be ANYTHING.
BeachBunny is offline   Reply With Quote
Old 06-16-2005, 11:21 AM   #5 (permalink)
thekid's Avatar
well sh*t... I just realized that was a dump question... let me rephrase... Drivers side, middle or passneger side... and is it left or right hand drive... Now we will know which side we are reffering to.
Old 06-16-2005, 01:49 PM   #6 (permalink)
[snapback]354122[/snapback]
Right, took the car to the BMW garage, they knew what it was straight away, it's the ABS doing a self check at 5mph! this explains why it only happens when the engine it switched on, and when you switch the engine off and back on!. So for any of you that may be having the same problem that is what it is! the ABS!
Old 06-17-2005, 09:23 AM   #7 (permalink)
pcy
pcy is an unknown quantity at this point
Are you saying that the ABS pump is [making that noise] going through a self-test ? Did the dealer tell you that it is "normal" noise or that the pump is slowly going bad?
pcy is offline   Reply With Quote
Strange Noise RedlinedRU 3-Series (E36) 11 12-15-2005 12:46 PM
Strange Noise 99bmw 5-Series (E12,E28, E34, E39, E60) 1 06-25-2005 12:22 AM
Help !! E46 328i Strange Noise !!!! MohanUK 3-Series (E46, E90) 2 10-14-2004 03:27 PM
Strange Noise 93 325i 3-Series (E36) 4 10-11-2004 11:31 AM
Strange Rear Wheel Noise? Clint_M 3-Series (E36) 1 10-04-2004 06:37 AM
