strange idle behaviour-automatic - BMW Forum - BimmerWerkz.com
Old 10-09-2009, 04:54 PM   #1 (permalink)
wernermeister is on a distinguished road
I got a 1994 325i with auto transm. about 110Kmiles.
Here is the challenge:
if transmission is in "D", and I come to a stop, the idle keeps popping/moving between about 500rpm all the way up to 900-1000rpm up and down.
If I have it in "3" gear, it is rock steady at about 700rpm.
So, I started checking into this, and here is what is so strange:
if in "D", and I just touch the shift lever and push it ever so gently towards the "3" gear, it immediately goes steady to 700rpm; if I let go, it starts jumping again.
So, can somebody please explain how this can be (i.e. relationship of gear and idle); and more importantly, how do I fix this?
Is there an easy way to "adjust" that shift lever???
Appreciate your help!
wernermeister is offline   Reply With Quote
Old 10-14-2009, 02:42 PM   #2 (permalink)
MADDOUG is on a distinguished road
There is a gear lever selector switch underneath the gear lever surround that tells the ecu that controls the box what gear the car is in.
It is about 3 inches long and you will see it can be taken apart and cleaned but it is best to remove it and spray contact cleaner inside it.
It may be worn out or have had some clutter from inside the car fall in to it
MADDOUG is offline   Reply With Quote
Old 10-14-2009, 02:50 PM   #3 (permalink)
RealOEM.com * BMW E34 525tds Gear shift parts,automatic transmission
The parts drawing is for my car a 94 tds but yours will be the same or select yours on that link.
You have the switch and also the cable .
The cable can be adjusted although I have never done one.
Sounds like your engine management is getting the signal that the box is in neutral and drive off and on hence the rev jumping
Old 10-15-2009, 05:21 PM   #4 (permalink)
Thanks Maddoug
next time we have a "dry" weekend to work on the car I will taggle this cable adjustment thingy.
Appreciate your help.
Strange idle - transmission related problem wernermeister 3-Series (E36) 0 10-08-2009 07:14 PM
Strange idle problem, need advice... mphilly77 3-Series (E36) 4 10-01-2009 02:45 PM
Strange random vibration at idle zabak80 3-Series (E36) 5 05-24-2009 03:19 PM
Perplexing Idle behaviour (325e auto) :conf shin_arkhangel 3-Series (E21, E30) 9 04-07-2009 10:05 AM
BMW 318i 1996 strange behaviour >?< hmm benny 3-Series (E36) 6 06-19-2004 06:46 PM
