Still Need Help Finding A Shaking Issue. - BMW Forum - BimmerWerkz.com
Old 11-22-2004, 10:17 AM   #1 (permalink)
jroberts312 is an unknown quantity at this point
My front end will shake if I am going about 60-70mph and I curve to the left. It does not shake going straight or veering to the right. For some reason it does this only to the left. It is not my rotors or tires. Had them checked out. Does anyone have an idea? Will have a mechanic check in a few days but would like to do something sooner.
jroberts312 is offline   Reply With Quote
Old 11-22-2004, 10:19 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
If I was you.. I'd get under the car.. and look around at all of your bushings.. most of your suspension components connect to each other with rubber bushings.. after a while they wear thing and dry root and die... thus giving you things such as what you speak... look around and see if you can see anything like this mainly on the left side..
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 11-22-2004, 03:46 PM   #3 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
you need to checkout the wheel bearings. they tend to vibrate and cause noises like you described. its either that or bushings.
abemcclellan is offline   Reply With Quote
Tiptronic issue - 325i 2003 freetodd24 3-Series (E46, E90) 1 10-14-2005 02:48 PM
Any Issue For Putting Obd I M3 Engine In 325i? r6bruin 3-Series (E36) 2 08-13-2005 07:12 AM
Bumper/bodywork/scratchpad Issue RokleM 3-Series (E46, E90) 4 08-04-2005 04:47 AM
2002 E39 530da Shaking When Idle larscph 5-Series (E12,E28, E34, E39, E60) 11 11-12-2004 01:08 AM
Steering Shaking With And Without Hot Brakes zanick 3-Series (E46, E90) 3 10-26-2004 11:02 AM
