Still have a hesitation NEED HELP - BMW Forum - BimmerWerkz.com
Old 05-27-2007, 10:40 AM   #1 (permalink)
seven is on a distinguished road
Been working on my 1993 325 IS 5 speed car. I am getting a hesitation or sputtering at low RPM. If I nail the gas moving in gear or at idle the engine sputters until about 2500 RPM then runs smooth. If I ease the gas on it does not do this have changed plugs to NGK plugs # BKR 6EK they are dual electrode and cannot be gapped. The K&N filter was just cleaned all ignition modules checked and I am not getting any engine codes. Any would would be great Thanks
seven is offline   Reply With Quote
Old 05-29-2007, 06:28 PM   #2 (permalink)
kylek325i is on a distinguished road
Send a message via AIM to kylek325i
check all your vacuum lines and hoses; make sure connections are tight. make sure there are no obvious obstructions in intake/ exhaust...also check the throttle body assembly make sure its not sticking. do you have traction control?
kylek325i is offline   Reply With Quote
Old 05-29-2007, 08:16 PM   #3 (permalink)
Car: Opening soon:
Define sputtering: Is is a misfire? Popping noise out the intake? Stumbling? Or something else?
Old 05-30-2007, 09:40 AM   #4 (permalink)
Sal329's Avatar
Sal329 is an unknown quantity at this point
Dirty MAS? Sometimes the oil from the cleaning agents of the air filters get on the MAS and could cause a problem like that.
Sal329 is offline   Reply With Quote
Old 06-10-2007, 09:09 AM   #5 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
You may also want to check what fuel pressure is the fuel pump making,
5psi difference will make a big difference on actual fuel injected since it is a exponential relationship between fuel rail pressure and actual fuel injected trough the injector.
So you may also want to make sure that the pump is indeed in good shape...
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
318is Hesitation when hot MLC834 3-Series (E21, E30) 17 07-25-2006 04:39 PM
Engine hesitation 325i_family 3-Series (E36) 12 10-28-2005 04:22 PM
Hesitation & Check Engine Light jek1955 3-Series (E36) 3 03-15-2005 08:04 PM
Hesitation At Cruising Speeds idanity 3-Series (E21, E30) 8 11-24-2004 02:26 PM
HESITATION DURING ACCELARATION shield 3-Series (E21, E30) 1 08-31-2004 01:28 AM
