Sticking/creaky Accel Pedal - Lub?? - BMW Forum - BimmerWerkz.com
Old 03-04-2005, 07:14 AM   #1 (permalink)
Boxbrownie's Avatar
Boxbrownie is an unknown quantity at this point
Send a message via AIM to Boxbrownie Send a message via MSN to Boxbrownie
Hi, Does anyone know if the accel pedal linkage pivot at the top of the pedal is all plastic? And if so, what lubricant have you used on it with success?
Mine creaks with every movement, I dont want to put mineral based oil on it if its all plastice for obvious reasons, is there a recommended lubricant?
Best regards David
Boxbrownie is offline   Reply With Quote
Old 03-04-2005, 07:28 AM   #2 (permalink)
CiscoKid's Avatar
u used WD40 in the hinge, and it was fine
Old 03-04-2005, 08:26 AM   #3 (permalink)
Boxbrownie's Avatar
Yes, I was about to use WD40 when I thought it might be better to use a thicker lubricant, I have a tube of silicone grease and I might try that first tonight.
Its the same stuff, just thicker.....
Best regards David
Old 03-04-2005, 09:58 AM   #4 (permalink)
CiscoKid's Avatar
i actually used something else that was like WD40, but it doesnt squeek anymore, and i did it about 3 weeks ago. Just make sure you dont get any in the carpet
Need help with E34 accelerator pedal m3driver97 5-Series (E12,E28, E34, E39, E60) 4 10-03-2005 10:17 AM
Clutch Pedal Mount Tweaked 325eXTATIC 3-Series (E21, E30) 5 08-22-2005 03:55 PM
'94 318is Sticky Accelerator Pedal ultraviolet353 3-Series (E36) 8 01-25-2005 12:26 PM
My cluth pedal is tilted to the left... KingScare M-Series (M1, M3, M5, M6) 6 11-28-2003 01:33 AM
