STEERING WHEEL SHAKEING??? - BMW Forum - BimmerWerkz.com
Old 01-10-2004, 02:23 AM   #1 (permalink)
NVSBMW is an unknown quantity at this point
HEY WASSUP EVERY1,
I DRIVE A 318IS 5 SPD MANUAL, RECENTLY WHEN EVER I ATTEMPT TO HIT THE BRAKES AT A FAST SPEED OR EVEN A SLOW SPPEN MY STEERING WILL SHAKES LIKE RATTLES. ID BE LOOKING AT MY HAND AND ITS LIKE A VIBRATOR...ANYONE KNOW WHAT THIS COULD BE?? BRAKES??
NVSBMW is offline   Reply With Quote
Old 01-10-2004, 02:28 AM   #2 (permalink)
Defector
El Presidente's Avatar
sounds like a warped rotor.
Old 01-10-2004, 02:47 AM   #3 (permalink)
350z
Car: 03 Nissan 350z Track
everyone always says brake rotors but i went in and got my alignment fixed, and my shakes from 60 to dead stop or higher speeds went completely away my 318 had the sameprobelm. like annoying pretty hard shake! i even got it on the accelration too that sucked! alignment fixed my problem!
David
**BAKER POW REPORT**
Old 01-10-2004, 09:11 AM   #4 (permalink)
FastFreddy is an unknown quantity at this point
definetly sounds like a warped rotor dude! I had the same problem.
&lt;html&gt;
&lt;body&gt;
&lt;p align=&quot;center&quot;&gt;&lt;b&gt;&lt;font size=&quot;2&quot; face=&quot;Copperplate31ab&quot;&gt;We're on your ass BENNY-BOY!!!!&lt;/font&gt;&lt;/b&gt;&lt;/p&gt;
&lt;p align=&quot;center&quot;&gt;&lt;img border=&quot;0&quot; src=&quot;http://www.geocities.com/torrienta/U...yF16.jpg&quot; width=&quot;300&quot; height=&quot;245&quot;&gt;&lt;/p&gt;
&lt;/body&gt;
&lt;/html&gt;
FastFreddy is offline   Reply With Quote
Old 01-10-2004, 12:04 PM   #5 (permalink)
Defector
its true it could be alignment, but if it were theres a good chance it would be noticeable w/o using the breaks because the car would't track straight.
Old 01-10-2004, 02:30 PM   #6 (permalink)
350z
yea mine was noticable even without the brake, so if it only happens with braking rotor, all the time alignment 50$
David
Old 01-10-2004, 03:48 PM   #7 (permalink)
...just a strange thought... maybe you should undo all the lugs on each rim, and re-torque them down in accordance with the correct bolt-pattern-tightening-sequence. maybe you have a loose lug. ...just ah thought, and wouldnt cost a dime.
&lt;html&gt;
&lt;body&gt;
&lt;/body&gt;
&lt;/html&gt;
Old 01-10-2004, 10:35 PM   #8 (permalink)
gbf1lm is an unknown quantity at this point
i think its a warped rotor but im not sure, but either way, most of the time when a steering wheel is shaking, its somehow connected to the brakes.
1992 brilliant red 325i 5 speed.
<img src='http://gbf1lm.i8.com/bmw.jpg' border='0' alt='user posted image' />
gbf1lm is offline   Reply With Quote
Old 01-10-2004, 10:49 PM   #9 (permalink)
mikester328's Avatar
mikester328 is an unknown quantity at this point
Send a message via AIM to mikester328
ahh on my 318i mine did the exact same thing... shook when I barely hit the brakes and then if i hit them harder, the steering wouldn't shake. I got new tires for my car and everything is smooth.
mikester328 is offline   Reply With Quote
Old 01-12-2004, 10:54 PM   #10 (permalink)
youvebeensmoked is an unknown quantity at this point
i had the same problem on my 328, a new rotor was all i needed.
youvebeensmoked is offline   Reply With Quote
Old 01-13-2004, 01:07 AM   #11 (permalink)
Aggieland81's Avatar
Aggieland81 is an unknown quantity at this point
Send a message via AIM to Aggieland81
Ah yes but what if you have brand new rotors and your wheel shakes between 40-50 mph?
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1083708618.jpg' border='0' alt='user posted image' />
Aggieland81 is offline   Reply With Quote
Old 01-13-2004, 12:22 PM   #12 (permalink)
Defector
tires are worn unevenly, in need of balance, or your alignment is off.
Old 01-13-2004, 05:57 PM   #13 (permalink)
thekid's Avatar
mine does it as well, however, from what I can tell the alignment on mine is good. I can drive in a straight line with out touching the steering wheel. However, it's not a bad shake, as long as my hands on the wheel it really doesn't cause problems. And a warped rotar is a very common cause for the wheel to shake while braking. Plus, telling if your rotar is warped is something you can do your self too.
Old 01-13-2004, 10:33 PM   #14 (permalink)
then switch to decaf
Old 01-13-2004, 10:42 PM   #15 (permalink)
TECH's Avatar
Tire balance, bad tire, worn suspension component - if simply driving and not braking. Which car? How many miles?
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
Steering Wheel / Steering Feeling {|nf3rn0} 3-Series (E36) 0 10-21-2004 03:23 AM
Triangle 3 spoke Sport Steering wheel woobiee Classifieds Sell & Buy 11 10-03-2003 03:08 PM
