steering wheel shake - BMW Forum - BimmerWerkz.com
Old 04-30-2004, 10:33 PM   #1 (permalink)
mikester328's Avatar
mikester328 is an unknown quantity at this point
Send a message via AIM to mikester328
hey, just wondering if anyone knows what might be causing the steering wheel to shake when I put on the brakes. It occurs mainly when I'm pressing the brakes lightly. Does it have to do with the rotors or tire balance? I have a 318i '96. Thanks.
-Mike
mikester328 is offline   Reply With Quote
Old 04-30-2004, 11:14 PM   #2 (permalink)
Kevin325i's Avatar
Could be one of about a thousand things, most commonly your rotors may be warped. But to really give you an answer we'll need more details like how fast are you driving? Is it only from highspeeds? Around town?
Kevin
Kevin (President TBEA)
Old 05-01-2004, 12:55 AM   #3 (permalink)
PilotPhil is an unknown quantity at this point
I had the same problem. Ordered a new set of rotors, pads and (just in case) sensor for the front axle, and the problem's solved. It's about a 45 minutes job that I was able to successfully accomplish in two hours.
PilotPhil is offline   Reply With Quote
Old 05-01-2004, 01:39 AM   #4 (permalink)
ex owner/admin
Furious's Avatar
usually a rotor is warped
Old 05-01-2004, 06:01 AM   #5 (permalink)
Eggrolled211's Avatar
Eggrolled211 is an unknown quantity at this point
yeah warp rotor...when braking etc. lightly....steering shakes at 65+.....tires aren't balance...or could be aligment?
<img src='http://l00062.myspace.com/00062/50/89/62019805_m.jpg' border='0' alt='user posted image' />
Eggrolled211 is offline   Reply With Quote
Old 05-01-2004, 07:07 AM   #6 (permalink)
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
Just had mine done a couple weeks ago and it feels like another car!
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline   Reply With Quote
Old 05-01-2004, 08:03 AM   #7 (permalink)
Super Moderator
dutchbmw's Avatar
A warped rotor because it is only shaking when breaking! :P
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 05-01-2004, 12:04 PM   #8 (permalink)
Aggieland81's Avatar
Aggieland81 is an unknown quantity at this point
Send a message via AIM to Aggieland81
I just had my mechanic replace my rotors and pads about 5k miles ago, should i have take my car back in and have him look at, or since there new is it not a warped rotor, mine only shakes when braking from speeds higher than 55+ if im going 80 it will shake till 55 unless i slam on them then it wont shake, My wheel also shakes at about 40-50 mph just driving around town. THanks
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1083708618.jpg' border='0' alt='user posted image' />
Aggieland81 is offline   Reply With Quote
Old 05-01-2004, 10:28 PM   #9 (permalink)
Thanks for all your replies.
The other day I had about 250 pounds of stuff I was needing to take home in my car and when I was going about 50 mph it shook probably the worst... that was when braking fairly easily, but the harder I pressed at that moment, the faster it shook but the shaking wasn't as wild... I think that could be the warped rotors... It happens all the time even though there isn't any extra weight in the car. Thanks for the help.
Btw, I think it's amazing that I'm member 4000... right on the money with the number... hahah.
Mike
Old 05-01-2004, 10:32 PM   #10 (permalink)
CiscoKid's Avatar
how hard it is to change your rotors?
Old 05-02-2004, 02:34 AM   #11 (permalink)
Defector
El Presidente's Avatar
not very. I changed mine about a year or two ago. Take off wheel, take off anti clip, undo allen bolts holding on caliper, remove caliper, remove pads, remove allen bolt holding rotor, install is reverse.
Old 05-02-2004, 09:07 AM   #12 (permalink)
CiscoKid's Avatar
thanx
Old 05-02-2004, 08:20 PM   #13 (permalink)
Kevin325i's Avatar
Get yourself a ruber mallet. Usually they're pretty rusted to the hub, when you get everything off just give it a good wack a few times.
Kevin
Old 05-03-2004, 07:19 PM   #14 (permalink)
Car: 97 328is, 93 318is
thinair is on a distinguished road
Send a message via ICQ to thinair Send a message via MSN to thinair
If it's shaking when you brake lightly if might not be your rotors...
Do you feel it in the brake pedal, or just the steering wheel?
Check your lower control arm bushings, tie rods, and ball joints for excess play.
Nelson Papel
1997 Madeira Violet 328is - Carbonio Intake, Racing Dynamics exhaust, fan delete, ASC delete, M50 intake manifold, M3 Cams, Eurospeed/AA software, 3.38LSD, M3 f&r brakes + MC, Bilstein PSS, Eibach swaybars, BBS RK 17x8&quot; wheels, Toyo T1R (235/40R17) tires, Racing Dynamics K55 kit, full euro lighting, 4300k HID lows, etc..........
<a href='http://www3.sympatico.ca/thinairbikes/bmw.htm' target='_blank'>Click here for more info on my car</a>
thinair is offline   Reply With Quote
Old 05-03-2004, 09:10 PM   #15 (permalink)
leibniz is an unknown quantity at this point
That's right. I believe the '96 model still had the plastic control arm bushings; which tend to be problematic.
leibniz is offline   Reply With Quote
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Steering Wheel Shake (even After Rotor Turn) SD318is 3-Series (E36) 10 08-13-2005 12:10 AM
Steering Wheel Shake... mech9T8 3-Series (E36) 17 07-03-2005 12:58 AM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
