Steering wheel rumble - BMW Forum - BimmerWerkz.com
Old 12-05-2007, 08:09 AM   #1 (permalink)
newbimmerowner1 is on a distinguished road
Well, I'm new to posting threads, but I just bought a 1997 328i sedan and I'm getting crazy rumbling from the steering wheel when I go over certain bumps at highway speeds. Also, kinda sounds like a clunking noise in the left front wheel when I hit certain areas of the road, but not all the time. Any suggestions? Keep in mind the guy put 18" wheels on with low profile tires...Thanks
newbimmerowner1 is offline   Reply With Quote
Old 12-05-2007, 02:15 PM   #2 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Check your Control arm Bushings, Ball Joints, and Tierods to start and see what that turns up..
1992 318i Coupe parts car
I am Captain Obvious
Old 12-06-2007, 08:12 AM   #3 (permalink)
Thanks, I'll be taking a look this weekend hopefully....he said he changed all the control arm bushings at 100k, and I'm at about 140k, so I'm guessing probably need replaced again?
Old 12-06-2007, 09:55 AM   #4 (permalink)
chinonca's Avatar
chinonca is on a distinguished road
I agree with alpinesix&seven! Common problem on bmers with high mileage! Done alot of suspensions on these cars!!
chinonca is offline   Reply With Quote
Old 12-07-2007, 02:01 AM   #5 (permalink)
bimmerguy82's Avatar
Car: 2004 ZHP 6SPD
honestly, you should not have to replaced them after 40k unless you were tracking your car every day. but tierods could give it a wobble.
BMWcrazy
___________
-Joshua
BMWCCA member#407674
Old 12-07-2007, 11:01 AM   #6 (permalink)
if they were ACTUALLY just replaced at 100k you should be fine mine are at 140k and still good all i need it a tierod probably the same for you just check them and post back
Old 12-07-2007, 11:23 AM   #7 (permalink)
Yep, definitely the bushings...tie rod and everything else looks great...had my mechanic look it over as well just to be sure and that's all he could find too. Now the question is...where to get the bushings? I'm not getting them from the dealer, so does anyone know of some good ones on the market that may last longer? Thanks for your help guys...
Old 12-07-2007, 11:48 AM   #8 (permalink)
chinonca's Avatar
Try these guys pretty reasonable for OEM replacement parts! BMW Parts and BMW Accessories | Bavarian Autosport , BMP design : BMW Parts, BMW Accessories & BMW Replacement Parts.. I think they even have performance ones.
Old 12-07-2007, 12:40 PM   #9 (permalink)
Car: 1994/BMW/325IS
Marknhl is on a distinguished road
Send a message via AIM to Marknhl
pelicanparts.com is also a very good site. I've used thepartsbin.com but I recently received the wrong part, reimbursement takes four weeks... idk if I'd recommend them.
Marknhl is offline   Reply With Quote
Old 12-07-2007, 01:11 PM   #10 (permalink)
What about polyurethane bushings? Are these ok for street cars, or would I be better off going with rubber?
Old 12-07-2007, 03:00 PM   #11 (permalink)
it depends on your driving style.... if your a "sprited" driver go with the poly just for a to b ecno style rubber....
Old 12-07-2007, 03:58 PM   #12 (permalink)
I decided to go with powerflex poly...they shipped out today...I'll let you guys know how they turn out...should get them tomorrow.
Old 12-07-2007, 10:26 PM   #13 (permalink)
Car: 2004 ZHP 6SPD
I heard from guys that the poly ones make too much noise for everday use. unless you are tracking your car stick with rubber.
BMWcrazy
___________
-Joshua
Old 12-08-2007, 05:30 PM   #14 (permalink)
he ordered the poly flex ones... from what i know there not to bad... and if they are.... it is time for a stereo upgrade! lol
noise in steering wheel ksee777 3-Series (E36) 9 04-29-2006 10:43 PM
Would this VICTOR steering wheel fit an E36? (see pics) Delmarco 3-Series (E36) 0 01-01-2006 03:43 PM
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
