| you might have a problem when the airbag is disconnected and the car is on...I'm not sure about that because i have never tried to start the car with the airbag unplugged....but if its not a problem and you have the 4 spoke steering wheel w/ airbag, there are 2 torque screws on the back of the steering wheel I believe they use a T30 ....when you unscrew those you should be able to take the airbag off...once removing the airbag you will see a bolt in the middle that holds the wheel on once you take that off the wheel can be removed....now make sure your wheels are straight or your gonna have a hell of a time trying to get the wheel aligned to the front wheels...also make sure you disconnect the battery when working with the SRS system , don't want an accidental deployment....let me know if you need more specifics B)
__________________ 92' 325is
5spd
ACS CS widebody kit
dinan stage 1 engine software
ACS short shift kit
ACS roof spoiler
ACS strut tower bar
ACS front spoiler
M3 mirrors
M3 steering wheel
clear corner fronts
bilstein sport shocks
17x8.5 (225/45/17) front
17x10 (275/40/17) rear
wheels made by WORK inc. motorsports (EQUIP series)
CAI and Aluminum radiator comming soon...... |
