steering wheel judder/vibrations - BMW Forum - BimmerWerkz.com
Old 08-28-2004, 05:40 PM   #1 (permalink)
Rich328's Avatar
Rich328 is an unknown quantity at this point
Send a message via MSN to Rich328
can someone please tell me what could be the cause of this problem!
When im braking in my car, the steering wheel starts juddering/vibrating, I've had the wheels balanced and everything is fine with that.
So i havn't a clue what else could be causing this - its starting to worry me - could it be something expensive which needs doing?
My dad thinks it might be some dirt/stone between the pads and the discs? could this be possible?
thanks
Rich328 is offline   Reply With Quote
Old 08-28-2004, 08:14 PM   #2 (permalink)
theogill is an unknown quantity at this point
Send a message via MSN to theogill
My guess is a warped rotor.
But, I'm new to BMW's.
98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17" wheels, larger sway bars.
theogill is offline   Reply With Quote
Old 08-28-2004, 09:01 PM   #3 (permalink)
It could be the control arm bushings or the ball joints (ball joints are part of the control arm).
Old 08-28-2004, 09:09 PM   #4 (permalink)
ChahalzBMR is an unknown quantity at this point
Does this only happen when you break? if yes then it could be your rotors or even brake pads. Check these two first, if they are fine, then check you ball joint..bushings...etc.
If it shakes even when you are not breaking just driving along, then it could be your tires or rims. If they are fine then for sure get your suspension components checked! Hope this helps....
<img src='http://img43.exs.cx/img43/275/Resize.jpg' border='0' alt='user posted image' />
Body: 318i 4 door
Mods: M50 engine, Jim C chip, light-weight flywheel, dual cat-back custom exhaust, 3:15 lsd, euro headlights w/angel eyes, 5300K HID, smoked corner lights, FK Motorsports foglights (crystal clear), ABS plastic upper eyebrow, clear side markers, M3 powered side mirrors w/LED, blacked out grill, M3 lighted shift knob, 17&quot; ROH Furry wheels w/Kumho tires, Brembo cross drilled rotors and Hawk performance brake pads all around, PSS9 Bilstein and H&amp;R coil over kit, front strut bar and Alpine alarm.
ChahalzBMR is offline   Reply With Quote
Old 08-28-2004, 11:06 PM   #5 (permalink)
/Banned
xsperf's Avatar
xsperf is an unknown quantity at this point
definetly 100% warped rotors, get zimmerman cross drilled, u can find real ones for not too much
xsperf is offline   Reply With Quote
Old 08-29-2004, 11:27 AM   #6 (permalink)
Rich328's Avatar
sorry if i sound dumb...... but what do u mean by 'warped'?
Old 08-29-2004, 06:11 PM   #7 (permalink)
chungaa1 is an unknown quantity at this point
warped= (not straight; not linear; etc...)
chungaa1 is offline   Reply With Quote
Old 08-29-2004, 08:17 PM   #8 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
besides rotors, your alignment could be off.
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 08-29-2004, 09:27 PM   #9 (permalink)
Threadkiller
bitcore's Avatar
Untrue.
Steering wheel shaking can be caused by numerous and combinations of things. Mine's starting to shake a bit and I believe it's because of my rotors since they are rather old now, and like my dumbass self, I may have gone to a carwash after driving it for a while one day...
Hot rotors + cold water = WARPING AND CRACKING... BAD BAD BAD!!!
Old 08-30-2004, 12:30 AM   #10 (permalink)
sean's Avatar
sean is an unknown quantity at this point
Send a message via AIM to sean
yah mine had been doing the shudder for awhile, it was because of the arizona heat, mixed with washing my car alot, the rotors warped a bit. the pads were worn down and a bit overly dirty as well.
<img src='http://img.photobucket.com/albums/v146/318ibmw318i/the_sig.jpg' border='0' alt='user posted image' />
signature designed by crisby_E30
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>
<span style='color:red'>Chairman</span> of the &quot;BMW-Forums...Cant hack it? Go Whack it... &quot; Mafia...&quot;We'll take your shoes&quot; </span></span>
sean is offline   Reply With Quote
Old 08-30-2004, 12:35 AM   #11 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
It's this. you have 2 control arms located in your front wheels.
I highly doubt warped rotors
also sumone mentioned misalignment.
dont ever say 100%
im 70 % sure it is control arms and other components of that matter. also alignment.
Old 08-30-2004, 12:45 AM   #12 (permalink)
Try toping off the power steering fuild. I had the same problem, but its goneeeeeeeeee.
Old 08-30-2004, 12:57 AM   #13 (permalink)
ClarenceT's Avatar
ClarenceT is an unknown quantity at this point
Originally posted by ///M Power+Aug 30 2004, 01:15 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (///M Power @ Aug 30 2004, 01:15 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Bear@Aug 28 2004, 09:41 PM
dont ever say 100%
im 70 % sure it is control arms and other components of that matter. also alignment. [/b][/quote]
OT, but sexy rex... got any more pics?
<img src='http://members.cox.net/edgetech/pics/clarencet.jpg' border='0' alt='user posted image' />
ClarenceT is offline   Reply With Quote
Old 03-12-2005, 05:00 AM   #14 (permalink)
abbamt is an unknown quantity at this point
I have had and still have the same problem, I have changed the tie rod, ball joint, control arm bushings, complete wheels and tyres and balanced, but the problem persists. it does the same thing when I reach speeds between 90- 130km/h.
It feels like the wheels are pulled in alternate directions very fast. definately not the wheels, suspension parts, only the rotor is what I have not heard of before. are these the break discs?
please help anyone.
abbamt is offline   Reply With Quote
Old 03-12-2005, 08:41 AM   #15 (permalink)
CiscoKid's Avatar
yes... after a lot of high speed braking, they begin to warp.. making the surface not straight. So when you apply the brakes, the car wiull wobble, because the brake pads are not touching the rotor surface 100% of the time.
If it only happens during braking, then it is the rotors. This was the problem with my car, and i replaced the rotors and it worked perfectly after that.
You could even go and get your rotors re-cut, but i would just get a new set of weither slotted or cross drilled. I would reccomend the ATE powerdiscs. They are cheap and they perform alot better than my old rotors after excessive braking
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
2004 325 with steering wheel off-set pmecca 3-Series (E46, E90) 1 05-07-2004 09:04 PM
Triangle 3 spoke Sport Steering wheel woobiee Classifieds Sell & Buy 11 10-03-2003 03:08 PM
