steering wheel click - BMW Forum - BimmerWerkz.com
Old 12-10-2003, 06:44 AM   #1 (permalink)
austinbm is an unknown quantity at this point
Last night, as I came home from work, I noticed a wierd clicking noise coming from
my steering wheel. It happens as you turn the wheel slightly form side to side. Not
much movement is required, just a jiggle will do it. Horn works fine, as do the blinkers which cancel fine. Anybody experience this?
austinbm is offline   Reply With Quote
Old 12-10-2003, 07:50 AM   #2 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
What make and model is your car?
Actually ive experianced like rust noises when i turn my streering wheel as well(92 325i), only when im turning going 5mph or less, any more speed and its ok,regarding your problem there is a rubber piece behind your wheel it might have started wear or it might also be there steering lock...dnt quote me though
Old 12-10-2003, 08:09 AM   #3 (permalink)
ex owner/admin
Furious's Avatar
im assume you mean in the steering column? can you isolate the noise? is it in the wheel or the column or further back?
Old 12-10-2003, 08:11 AM   #4 (permalink)
EXtech's Avatar
The most common reasons a clicking noise such as yours would happen is either a column bearing or the slip ring. Most likely the bearing though. How many miles and what year is it?
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 12-10-2003, 10:06 AM   #5 (permalink)
My car is a 1994 325i with 55k. Very clean, low mileage car, but still has occasional issues because of the age. Thanks to youz guyz for the snappy repliez.
The sound is coming from behind the wheel, but sound like it is in front of the column. Something with the interface. The snap ring idea sounds feasible.
Old 06-19-2004, 04:36 PM   #6 (permalink)
gasper11 is an unknown quantity at this point
I am having the same steering wheel problem. I believe it is a steering column bearing located on the upper column just below the steering wheel. Do you know if this is correct??
Thanks
Ken
gasper11 is offline   Reply With Quote
Old 06-19-2004, 07:44 PM   #7 (permalink)
skidog's Avatar
skidog is an unknown quantity at this point
Yeah, I have the same issue with mine...
<1992, 325i Convertible, M-Technik>
skidog is offline   Reply With Quote
Old 06-20-2004, 07:17 AM   #8 (permalink)
Super Moderator
dutchbmw's Avatar
There's a tow contact for the horn. When the cupper grease on it is too dry the little peg makes a noise you've heard. Remove you're steering wheel and make sure it is greased.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Steering wheel noise on 325xi on right turn rms 3-Series (E46, E90) 1 10-10-2005 11:19 PM
Bmw M-technic 2 Leather Steering Wheel schneider252 OEM Parts 4 04-22-2005 10:34 PM
Steering Wheel Upgrade Options gmal 5-Series (E12,E28, E34, E39, E60) 0 10-28-2004 08:25 AM
2004 325 with steering wheel off-set pmecca 3-Series (E46, E90) 1 05-07-2004 09:04 PM
Triangle 3 spoke Sport Steering wheel woobiee Classifieds Sell & Buy 11 10-03-2003 03:08 PM
