Steering Question - BMW Forum - BimmerWerkz.com
Old 12-21-2003, 03:25 PM   #1 (permalink)
Aggieland81's Avatar
Aggieland81 is an unknown quantity at this point
Send a message via AIM to Aggieland81
Ok, when im driving between 40-50 mph and only that speed, my steering wheel shakes. Sometimes mildly, but sometimes it can get pretty bad, i know that my front shocks are leaking and that i have a worn flex disc and rear shock mounts, could that be the cause of this? and why is it only between those speeds???
-Erik
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1083708618.jpg' border='0' alt='user posted image' />
Aggieland81 is offline   Reply With Quote
Old 12-21-2003, 03:37 PM   #2 (permalink)
whitebeemer328 is an unknown quantity at this point
balance your rims
whitebeemer328 is offline   Reply With Quote
Old 12-21-2003, 04:10 PM   #3 (permalink)
how?
Old 12-21-2003, 06:12 PM   #4 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
tire shop.
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 12-22-2003, 02:37 PM   #5 (permalink)
bmw_freak96 is an unknown quantity at this point
Send a message via AIM to bmw_freak96
that, but also, there it is a comon thing in alot of cars.. it has to do with the natural rythym of the wheels spinning in the wheel wells...i dunno if you ever learned about this suspension bridge in the u.s. where the wind started blowing at the same rythmic speed of the bridge and it started twisting and bending, and eventually it fell, the same thing happened in my mom's 2001 mountaineer, we rotated tires, re aligned everything, helped a little, but if your steering wheel and whole car overall kinda vibrate, thats most likely what it is... just get everything balanced
<a href='http://www.cardomain.com/id/bmwfreak96' target='_blank'><img src='http://images.cardomain.com/member_images/10/web/442000-442999/442561_4.jpg' border='0' alt='user posted image' /></a><a href='http://www.cardomain.com/id/bmwfreak96' target='_blank'><img src='http://images.cardomain.com/member_images/10/web/442000-442999/442561_5.jpg' border='0' alt='user posted image' /></a>
bmw_freak96 is offline   Reply With Quote
Old 12-23-2003, 04:23 AM   #6 (permalink)
Scarface's Avatar
Scarface is an unknown quantity at this point
Send a message via AIM to Scarface
I don't know about this rhythm theory but mine does the same thing and it is a warped rotor..Especially when I apply the brakes at higher speeds. I have seen a few other people on here post the same question and more than likely you have the same problem as we do. I would also go to a tire shop and have them check the balance on your wheels and tires to make sure...
-1998 BMW 540i6(Axis Penta 20's,M5 shadow grilles,trunk lip,led tails,oem front lip,PIAA lighting)
-2002 Cadillac Escalade(Zinik Luina 22's,OEM HID upgrade)
Scarface is offline   Reply With Quote
Old 12-23-2003, 04:33 AM   #7 (permalink)
Defector
El Presidente's Avatar
I had the problem when I first got my car. My problem was the way the tires had been worn in. Rotating and balancing are probably your best options, and then alignment. If that doesn't work, new tires are the only fix.
Old 12-23-2003, 07:02 AM   #8 (permalink)
350z
Car: 03 Nissan 350z Track
yeah my car has that same problem and its mainly when i am slowing down, i also know that i need to go get my alignement fixed so thats what it probably is, how much does it cost to get your alignment fixed say at like les schawb?
David
**BAKER POW REPORT**
Old 12-23-2003, 10:26 AM   #9 (permalink)
Defector
I am not familiar with that chain, however the guys at goodyear explained to me that when I purchased said tires that if I needed an alignment then I would have to go to the dealership or special BMW garage, because most places dont have the know-how to do it properly on some european cars.
E34 V8 Steering Box Nightmare black_bird_blue 5-Series (E12,E28, E34, E39, E60) 2 02-23-2010 03:18 PM
Power Steering Reservoir Hose Question... dblmikeusa1 3-Series (E36) 3 09-02-2005 09:32 AM
Steering Wheel Question bmwultdrivinmach 3-Series (E36) 6 04-17-2005 12:14 AM
Link Play In Power Steering BMWhatever 5-Series (E12,E28, E34, E39, E60) 0 10-11-2004 12:23 PM
