Steering probs! - BMW Forum - BimmerWerkz.com
Old 05-06-2004, 06:22 AM   #1 (permalink)
ksamy is an unknown quantity at this point
Hope someone could help me on this one...Ive got a 320i coupe and the steering is rather heavy. It also makes sqeeky noises when i turn. Ive check the fluid and all seems good....any ideas??
ksamy is offline   Reply With Quote
Old 05-06-2004, 10:07 AM   #2 (permalink)
Car: 2008 128i
Add fluid to the powersteering.
2008 128i Jetblack
Old 05-06-2004, 10:13 AM   #3 (permalink)
kjlbryan is an unknown quantity at this point
I had the problem with the sound, and when i added the ATF fluid it went away... about the steering being heavy, i read in the service manual yesterday (by chance) that you you check and maybe tighten the V-Belt.
kjlbryan is offline   Reply With Quote
Old 05-06-2004, 10:35 AM   #4 (permalink)
Car: 2008 128i
If he is low enough on fluid steering could become heavy but if adding the ATF fluid doesn't fix things then check the v-belt...
2008 128i Jetblack
Old 05-06-2004, 11:02 AM   #5 (permalink)
kamikazinyc's Avatar
kamikazinyc is an unknown quantity at this point
Always use ATF check see if you're leaking from the pump.
DREMEL is South Africa Engineer's best friend
<span style='color:blue'>HID all the way </span>
kamikazinyc is offline   Reply With Quote
Old 05-06-2004, 01:18 PM   #6 (permalink)
roguesniper1's Avatar
Car: 97 528i and 94 325i
roguesniper1 is an unknown quantity at this point
Send a message via AIM to roguesniper1
ATF is for girls. REDLINE is the way to go.
roguesniper1 is offline   Reply With Quote
Old 05-11-2004, 02:43 AM   #7 (permalink)
Thanks peeps. got it booked it to a garage tom. Hopefully its just the v belt that needs tigtening
E34 V8 Steering Box Nightmare black_bird_blue 5-Series (E12,E28, E34, E39, E60) 2 02-23-2010 03:18 PM
Procrastination Is From The Devil: Power Steering drz 3-Series (E36) 8 04-01-2005 05:02 PM
Link Play In Power Steering BMWhatever 5-Series (E12,E28, E34, E39, E60) 0 10-11-2004 12:23 PM
1997 318i Steering Problem nickbarbar 3-Series (E36) 4 07-23-2004 10:26 AM
