Steering problems - BMW Forum - BimmerWerkz.com
Old 03-28-2004, 02:45 PM   #1 (permalink)
BUSTaMOVE is an unknown quantity at this point
When i am driving and am braking hard around a corener the steering makes a whining noise and gives a little resistance . then it goes away in 10 min of drivng .. any help with what it could be
BUSTaMOVE is offline   Reply With Quote
Old 03-29-2004, 03:10 AM   #2 (permalink)
Super Moderator
dutchbmw's Avatar
Check the power steering oil level. Or, I do not hope for you, a malfunction of the p. steering unit
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 03-29-2004, 05:20 PM   #3 (permalink)
the level is alittle low but nothing horrible what kind of fluid should i get
Old 03-30-2004, 03:17 AM   #4 (permalink)
Super Moderator
dutchbmw's Avatar
The fluid you should get is an ATF power steering oil(e.g. Shell DexronII). This is normally available at any filling station..... Another possibility for the whining noise you hear, is a slack belt. Inspect this belt at tighten force, or install a new one...
The last thing you can do is to de-air (right word????) the oil pump. Carry out the next points:
- Fill the hydraulic circuit (engine off) untill the 'MAX' sign (at level stick)
- Start the engine
- Turn the steering wheel twice from left to right and untill the ends
- Check the fluid level again (with engine off) When you have to fill again, there was some air in the system!
Pieter
BMW '96 M3 (SOLD)
Old 04-02-2004, 02:32 PM   #5 (permalink)
enefer is an unknown quantity at this point
May be a really stupied question I have the same issue on a Compact 318ti could some one please advise me where I can locate the power steering oil container
many thanks in advance
john
enefer is offline   Reply With Quote
Old 04-02-2004, 02:57 PM   #6 (permalink)
M3Daemon's Avatar
M3Daemon is an unknown quantity at this point
john
It sits about 40cm under the air intake manifold on the right side of the engine block. It is pretty tough to reach ( I could smack the engineer who came up with that design )
Daemon
<img src='http://www.geocities.com/bwloka/BimmerWerksSigV1.jpg' border='0' alt='user posted image' />
M3Daemon is offline   Reply With Quote
Old 04-02-2004, 06:02 PM   #7 (permalink)
thekid's Avatar
Also check your drive belts. I had a whine in my steering when I would turn the wheel all the way at low speeds. This may be the forebearer of the noise that i was hearing. Worth a look any way while your under the hood.
Old 04-03-2004, 05:30 AM   #8 (permalink)
a little fluid fixed it right up thanx guys
Steering Problems On E34 Iceblue56 5-Series (E12,E28, E34, E39, E60) 4 06-25-2005 12:18 AM
Help??? Steering Rack Problems ArtCarr 3-Series (E36) 1 02-08-2005 10:16 PM
Steering Problems DarrellS 3-Series (E36) 0 11-18-2004 05:24 AM
3 Series Steering Problems Yeshu777 3-Series (E36) 2 09-29-2004 08:47 AM
power steering problems khoi 3-Series (E36) 2 04-29-2004 01:29 PM
