| Is it a grinding noise.. or a squeeking noise.. for the grinding... you might have a bad power steering pump.. or your low on fluid... (Remember..ATF fluid.. not power steering fluid..) for the squeeking.. sounds like your belt is either worn.. or loose...
Good Luck,
Les`
1997 E36 M3 1990 E30 325i |
