Starting Takes Time! - BMW Forum - BimmerWerkz.com
Old 01-01-2005, 02:04 AM   #1 (permalink)
einstine98 is an unknown quantity at this point
I am having a problem in starting the car in the morning... it takes few tries and long cranking until it does...
after in operational temp. it just takes long to start, but not many tries
einstine98 is offline   Reply With Quote
Old 01-01-2005, 02:41 AM   #2 (permalink)
bmwboyzz's Avatar
bmwboyzz is an unknown quantity at this point
ok
<a href='http://WINDOWS\Desktop\Polish-Lancer-3.jpg&quot;&gt;&lt;input' target='_blank'>http://WINDOWS\Desktop\Polish-La...t;&gt;&lt;input</a> type=&quot;submit&quot; value=&quot;click here&quot;&gt;&lt;/form&gt;
bmwboyzz is offline   Reply With Quote
Old 01-01-2005, 06:16 AM   #3 (permalink)
Thanks,,, thought I'd share the news with everyone!
ghead
Any help on diagnosing the problem?
Old 01-01-2005, 07:45 AM   #4 (permalink)
Super Moderator
dutchbmw's Avatar
Check:
-Compression
-Fuel pump
-Spark plugs
Just a start, good luck!
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 01-01-2005, 09:14 AM   #5 (permalink)
Thanx for the reply!
Fuel pump is a new one (just installed)
Spark Plugs (same thing).
What compression should I check? fuel?
is there an easy way to do that (other than the need for a pressure guage?)
used
Old 01-01-2005, 01:56 PM   #6 (permalink)
Super Moderator
dutchbmw's Avatar
How many km/miles are on it? I've meant the cylinder compression. Almost every car workshop can test it.
BMW '96 M3 (SOLD)
Old 01-01-2005, 03:08 PM   #7 (permalink)
Storamin's Avatar
Storamin is an unknown quantity at this point
Have your local autoparts check your battery. It could be the culprit.
Storamin is offline   Reply With Quote
Old 01-01-2005, 10:21 PM   #8 (permalink)
I have 130k on it.... It does not seem to have a problem with momentum?! I don't know if it needs compression check in this case,, but I will try it as a last resort..
Old 01-01-2005, 10:22 PM   #9 (permalink)
[snapback]262213[/snapback]
It actually could be!!! I took the battery out, cleaned the connectors and returned it.. and it did improve (a bit)... I will investigate it more...
Thanks!
Old 01-02-2005, 10:44 PM   #10 (permalink)
spoolindynamics is an unknown quantity at this point
I have a 93 325i, i just go it... is it normal for the car to rev at a high rpm wen started??
C:\Documents and Settings\Cabanban Family\My Documents\My Pictures\Car
spoolindynamics is offline   Reply With Quote
Old 01-03-2005, 01:58 AM   #11 (permalink)
[snapback]262949[/snapback]
I'm not sure, but if you mean erratic rpm, then at idle speed, it could be Idle control valve (ICV). Although I have this problem in my car, and no one is able to identify the actual culprit! it only happens on cold starts :-(
Old 01-03-2005, 08:00 PM   #12 (permalink)
oh ok thanks a lot..does yours really do it?.... im thinking its this hose look a like thing that goes frmo the back of the alternator to the some area near the top of the radiator...wen i got it .. it had a big ass hole on the side... haha so thanks anyway
Old 01-03-2005, 08:02 PM   #13 (permalink)
BMW 318i 92Model E36 Starting Problems deanbelich 3-Series (E36) 7 09-21-2005 11:41 AM
Trouble Starting Car After Rain Jentlefur 3-Series (E36) 3 07-26-2005 01:28 PM
Starting Problems BMWDriver86 3-Series (E21, E30) 15 02-09-2005 04:28 PM
Cold Starting _1634_ 3-Series (E36) 2 09-07-2004 04:03 PM
