Starting problems! - BMW Forum - BimmerWerkz.com
Old 05-04-2010, 09:56 AM   #1 (permalink)
Car: BMW 318iS
chris17553 is on a distinguished road
Unhappy Starting problems!
I have a 1997 (four-door) 320iS. In winter, if the weather falls to zero or below, the car will not start at all. Outside of winter, if it has been a cold night the car will start, but takes an extremely long time to do so. In both these situations, the starter motor is lively and active, - it’s just that the cylinders won’t fire. When the weather is warm, however, the engine fires up straight away no problem.
I thought that a new set of sparkplugs might cure the problem, or perhaps a change of oil, (the oil is low). When I gave the above description to my local garage, however, I was told it could be a faulty temperature sensor. Apparently there is a sensor which, upon starting, tweaks the engine in response to outside ambient conditions.
Am just wondering if anyone else has experienced a similar problem or has any advice?
chris17553 is offline   Reply With Quote
Old 05-04-2010, 12:59 PM   #2 (permalink)
dcuse32's Avatar
dcuse32 is on a distinguished road
Chris the temp sensor would be bad if the car was overheating. I would check the ignition coils. try to get a free diagnostic check. I don't know where you live but autozone will do it for free.Heres a link for it:
dcuse32 is offline   Reply With Quote
Starting problems!.... BMKid 3-Series (E21, E30) 7 10-05-2009 03:10 AM
starting problems trigger_89 3-Series (E36) 4 08-17-2009 12:23 PM
Problems starting usna09 3-Series (E36) 4 07-19-2007 10:03 PM
Problems Are Starting...please Help Bimma328 3-Series (E36) 3 04-13-2005 08:08 PM
Starting problems jopa 5-Series (E12,E28, E34, E39, E60) 8 07-03-2004 12:52 AM
