starting problem - BMW Forum - BimmerWerkz.com
Old 03-16-2009, 11:23 PM   #1 (permalink)
wmich325is is on a distinguished road
starting problem
i own 1995 325is with about 130000 miles on it, i changed the fule pump about a month or so ago and after that the car had problems starting. some times it would start up fine and run perfect, other times it would take cranking it 2 3 or 4 time to start up but run fine. also check e light comes on every so often but i cant get the code, think it because it always goes away. any idea?
wmich325is is offline   Reply With Quote
Old 03-17-2009, 05:56 AM   #2 (permalink)
carparts.abhi is on a distinguished road
Check the fuel supply pipe. I think the problem is there.
BMW M3 Coupe BMW Performance Chip
carparts.abhi is offline   Reply With Quote
Old 03-17-2009, 11:04 AM   #3 (permalink)
The fuel rail? also i noticed this moring that sometimes the fuel pump primes sometimes i doesn't. that give any other ideas? thanks
Old 03-17-2009, 11:29 AM   #4 (permalink)
basrite's Avatar
Car: 1995 BMW 320i, 17inch M3 mags
basrite is on a distinguished road
either the feed lines or pump have an issue. The relay may be faulty too if it doesn't prime. Not sure.. cant hear mine as its brand new. (simple fuel leak turned into new senders/pump plus the leaky pipe).
Yes... i'm a total car nut! Why else would I upgrade my mower to rev to twice its standard rpm!
basrite is offline   Reply With Quote
Old 03-17-2009, 02:12 PM   #5 (permalink)
checked the lines an replaced the relay stll doing same thing, i remember reading something about the crank position sensor could that be my problem?
Old 03-17-2009, 08:36 PM   #6 (permalink)
Car: 1982 BMW 320i total restore
King Bo is on a distinguished road
your fuel injectors could be clogged up. and i would check the fuel filter.
King Bo is offline   Reply With Quote
Starting Problem Mike Brink 5-Series (E12,E28, E34, E39, E60) 0 07-29-2008 05:57 AM
Starting Problem 95540guy 5-Series (E12,E28, E34, E39, E60) 12 10-19-2007 11:50 AM
Please help with starting problem! BW330 3-Series (E46, E90) 10 08-04-2007 01:11 PM
Starting problem Rich328 3-Series (E36) 0 06-05-2004 06:45 PM
Starting Problem CaptainEL 5-Series (E12,E28, E34, E39, E60) 0 05-03-2004 04:39 PM
