Starter Replaced, But Problem Again - BMW Forum - BimmerWerkz.com
Old 05-12-2005, 12:10 AM   #1 (permalink)
brien4787's Avatar
brien4787 is an unknown quantity at this point
Send a message via AIM to brien4787
i replaced my starter one week ago.... took be way long enough to get that new sucker on there(and old one off).... when ever i have started the car it sounded a bit strange..but someone told me that it would for the 1st 2 weeks because it has to break in... not sure about this though...
all the sudden, today, when i start my car..it wont start at first... i will hold the key..the starter will spin, then stop spinning because its done with its cycle and it doesnt hit the fly wheel to make it spin...then it goes again(since i am holding the key) and it hits the flywheel starting the car... when it does start...it seems really sudden and doesnt sound all that great..but it does start...
what do you think is going on? bad stater? the starters bolts securing it to the tranny loose? something catching the tranny?
enlighten me if any of you have knowledge of this subject.
oh yeah... are there supposed to be only 2 securing bolts to hold the starter to the tranny, or 3? i have 2...but there are 3 holes... hmmm ajfwlgxs
brien4787 is offline   Reply With Quote
Old 05-12-2005, 05:58 AM   #2 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
Well.. .sounds like your starter isnt exactly set right.... I'd take a look at it and make sure the bolts are in the correct spot...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 05-12-2005, 09:27 AM   #3 (permalink)
brien4787's Avatar
there are only 3 holes out of 2 bolts...and i know that the empty one was empty before..... think my bolts need a retighten?
also..what about the weird nosie(break in noise) for 2 week thing..sound right?
Old 05-12-2005, 02:07 PM   #4 (permalink)
e36surge's Avatar
You are supposed to have three bolts for three holes. If you do not secure the third you will have a malfunctioning starter... starting sometimes and not at other times. Eventually your starter will fail if you do not fasten the third bolt. BMW put it there for a reason. Odds are the starter you just replaced was not the original, and odds are the mechanic who replaced it didn't want to go thru putting the third one back in. There is a long way and a short way to replace a starter. The long is from above, removing the intake manifold and thus accessing the starter or the short way, from below with the car lifted. If the mechanic is really good he can do it from underneath. However, as was in my case, the mechanic did not replace the third bolt because it is next to impossible to replace from underneath the vehicle... and I learned the hard way...
Starters use extreme amounts of force to get a motor started... have you ever lurched your car forward because you forgot to place your gearbox in neutral when you started your car? The noise is probably your starter vibrating, moving or straining because the third bolt is not fastened, it's twisting on it's axis, not by much but enough for it not to initiate the fly wheel. I hope this helps in some way.
Good luck
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 05-12-2005, 02:58 PM   #5 (permalink)
brien4787's Avatar
i actually did the starter myself... in the original starter..there were only 2 bolts....
i didnt take any short cuts... i got the hard to access bolt...the one where you need to take the intake manifold off, TRY to get a wrench down onto that bolt, drop the back of the tranny a few inches,get a long ass extension and somehow get that bolt off..then the easier one that you can get just from under the the car...
but for the 3rd..i didnt have a bolt...
i guess i need to get that bolt on there..(and find one to buy)
the noise that it makes when it starts is a funny eeee eeee eeee noise...not the starter rolling around and hitting something else that is metal such as the tranny.aklwel;gjws
im going to my mechanic right now to have them check it out.
Old 05-12-2005, 03:14 PM   #6 (permalink)
e36surge's Avatar
I may have typed it the wrong way. What I meant is perhaps the broken starter you just replaced yourself was installed by someone else when it was new who didn't bother putting the third bolt back on. I don't know if you're the original owner of the car, so my input was based on my experience. Factory e36 starters were fastened with three bolts... just called my friendly neighbourhood bimmer parts store.
And then the next question is... I don't remember but are the bolts all the same length? It's been two years since I did mine... think I'll call him again
I believe I got the bolt from the same parts store here in Montreal that specializes in Euro cars... wasn't expensive
good luck
Old 05-12-2005, 11:48 PM   #7 (permalink)
brien4787's Avatar
ya, both bolts are the same size...
my mechanic said that some did only have 2 bolts
Starter Problem atifhalim 3-Series (E36) 3 07-12-2005 10:26 AM
Car Won't Start Starter Relay Suspected BImmerN2B 3-Series (E36) 5 06-24-2005 06:36 AM
Problem Starting 325ic napalm 3-Series (E36) 4 06-17-2005 04:05 PM
X5: 0-60 in 4.0 tcpgv 1,6,7,8 - Series and Mini Cooper 6 03-30-2004 02:51 AM
